Scott_Hower
Saturday morning I delivered the block, crank, rods, flywheel and front pulley to the machinist (1500 engine). Also gave him the new pistons (County 9:1), rings, bushings and bearings (King tri-metal).
The list looks like this:
bake and shot blast the block (Sunnen engine cooker)
check line bore
check deck
bore+hone .020 over
clean and magnaflux crank
regrind 0.010 undersize main journals
index regrind .010 undersize rod journals
micropolish crank
clean and shotpeen rods
check rods for bend and twist
install and size small end bushings
resize big ends
check/file ring gaps
zero balance rods/pistons/pins; assemble
reface flywheel
dynamically balance front pulley/crank/flywheel assembly
Am I missing anything?
check line bore
check deck
bore+hone .020 over
micropolish crank
resize big ends
reface flywheel
