TR2/3/3A Differences in 2 TR3s
Webb Sledge
From a couple photos I have on my computer, I noticed that a '58 TR3 has it's tach on the left, while a '61 has it's tach on the right. Was this a change by Triumph, or are one of these incorrect?
SeanTR3
I just went out to look at my Dad's 1958 TR3A and the tach is on the left. I'm not sure if they made a change later.
SeanTR3
I sent you a link to yahoo photos so you could check out the dash photos I took tonight.
Sean
MGTF1250Dave
Aloha Webb,
The two TR3As that I've owned both had the speedometer to the left and tachometer to the right. The speedometer has a reset that extends below the bottom of the dash through a hole in the metal dash board. That hole should indicate were the speedometer was originally mounted. If there are two holes, I guess you can't be sure which is factory made or added later.
Safety Fast,
Dave
sammyb
I had to go to the "bible" (Original TR2/3/3A.) The location of the Speedo/Tach did not change throughout the whole production run, so it should be tach on right, speedo on left (even in a RHD car.)
Since most speedos have seen their knurled nut trip odometer resets fall/break off, it is common for shadetree mechanics to install the gauges in the wrong position...
...that being said, there's absolutely nothing wrong to put a gauge in a different place! Whatever works for you! On my car, the center knobs were put in the wrong order...I actually changed the knobs, but not the switches!!!! (So when you pull the lamps, you get the wipers!!!)
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
I thought all Brit cars were like that or worse.
Geo Hahn
[ QUOTE ]
[/ QUOTE ]
That does seem to be the most common arrangement, though oddly I they reversed them for LHD TR4s. The TR3 center gauges appear to have moved around a lot (looking at factory photos and Standard-Triumph wiring diagrams). I believe the switches were also moved (wiper & panel lights) when they went to a rheostat for panel lights.
Piggott's (that "bible")a good resource but I think even he would admit there were more variations and one-offs than can ever be accounted for.
William
I also imagine that anything could've been done to special order. It's not uncommon to see production build sheets for old Triumphs and whatnot with nonstandard colors or different trim as specified by the purchaser.
-Wm.
sammyb
Absolutely! Piggot even makes reference multiple times to the theory that if a paying customer wanted something, the factory produced it. Colors (Jay Blue, Ivory)and options like chromed wires were frequently offered when not officially on the options list.
[ QUOTE ]
-Wm.
[/ QUOTE ]
M TR2/3/3A Body Measurement differences between pre & post 60,000 TR3s Triumph 4
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
R TR6 Radiator protection shield differences Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Got_All_4 TR6 Looking at clutches and their differences for my 69 TR6 Triumph 14
J TR6 TR6 Cross Tube Differences? Triumph 6
CJD TR2/3/3A Knock Off Differences Triumph 13
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
D TR4/4A any major vendor differences in replacement suspension bushes? Triumph 5
R Differences in BJ7s Austin Healey 1
D Differences between BT7 and BJ8 engines. Austin Healey 12
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
T Differences in Armstrong Lever Arm Shocks Spridgets 1
Marvin Gruber TR4/4A TR4 hood differences Triumph 2
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
Scotsman GT6 GT6 early vs later model differences / upgrades Triumph 13
K TR2/3/3A Clutch and Gearbox Sleeve Differences. Triumph 12
B TR4/4A Body tub differences - TR4/4A Triumph 8
C Idler Arm Differences and Rebuild Question. Need Help! Austin Healey 2
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
Mink TR4/4A Dash/Crash pads - differences in quality between vendors? Triumph 8
RAC68 Dimensional Differences [brake Calipers] Austin Healey 5
Marvin Gruber TR5/TR250 TR250 Engine differences Triumph 2
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
K TR2/3/3A Differences in Distributors? Triumph 9
Got_All_4 Fuel Tank Differences Triumph 5
W Steering column differences Spridgets 0
Jim_Gruber Seat Differences between Mk 1 and Mk 2 Spridgets 10
K TR6 Differences in Chassis on 67 TR4A and 73 TR6? Triumph 8
bugedd Bugeye bonnet differences Spridgets 9
K TR4/4A 3A and 4A Clutch Component Differences? Triumph 19
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
J TR2/3/3A Frame differences in a TR3?? Triumph 17
M 4.0 V-8 for XJ8, XK8 and S-Type Differences? Jaguar 1
drooartz Starting to look for spare motor, differences? MG 2
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
C What are the differences in Midget MK2 and MK3 top Spridgets 6
Got_All_4 Wedge TR7 Head differences Triumph 1
R TR4/4A TR4A sway bar , any vendor differences Triumph 11
T TR6 Differences in ZS carbs for emissions TR6s Triumph 6
A Differences between 3000 models Austin Healey 8
RedTR3 TR2/3/3A TR3 Transmission Differences Triumph 27
AH224414 Differences between AHCA and AHCUSA Austin Healey 14
T TR6 Differences between TR4a and TR6 convertible tops Triumph 14
B frame differences Austin Healey 4
