MotorHead67
Howdy,
Haven’t checked in for a while. The Healey has been hibernating in the garage and I’ve been occupied with other projects.
I’m back on the road with this problem: I cant figure out why she diesels. The motor in my BJ8 has had some headwork by a competent motor builder, a hotter cam, new pistons, balance etc and headers. I’ve changed up to ‘UR’ needles.
I’ve run the engine with an INOVATE air /fuel ratio meter and I can get a good idle with a reading of 12 –14 afr but as soon as I come off idle she gets rich to about 8-9 afr. I’ve checked the distributor and timing all seems well. No Gas seeping past the jets with the pump swithed on. I’ve even tried a leaner ‘UH’ needles. With the lean ‘UH’ needles she backfires through the carb but I still read rich on my meter.
There is one thing- every now and then she starts to blow white smoke from the exhaust. I’m wondering if the brake booster is failing. Would this give me a rich condition? Would this create the white smoke? I haven’t tried running without the brake booster hose connected yet. Wonder if anyone has had this type of experience.
Mike
Mike
