Dash Lights Failure. A first I know...
veale001
Greetings all!
I have a 73 TR6 that is my favorite car Ive ever owned and I treat her like my first born. I was putting in a new speedo and there was a pop inside the dash!? Of course I should have unplugged the battery but since I wasn't really fooling around too much I figured I could knock it out during Playoff commercials :wall: Didn't work out. Long story short I thought maybe a fuse, but they all seem to be fine. The weirdest part is that my turn signal light still comes on but the dash lamps don't turn on when I turn the head lights on? I know this is all par for the British car course but I just wanted to see if anyone had a simple remedy or line of action I could take?
Any help would be greatly appreciated,
Warren
martx-5
According to the wiring diagram from Advance Auto Wire, the switch feeds a fuse which then goes to the tail lights, rear markers, license plate lamp, front parking and marker lights. Then it feeds the dash lights after going through the dimmer switch.
As far as the fuse goes, "seems fine" is not good enough. Check it with an ohmeter or turn on the headlight switch and check the voltage on both sides. BTW, it's the fuse fed by the red/geen wire on one side and two red wires on the other. See the wiring diagram I linked to.
If the fuse does turn out to be good, check to see if the tail and marker lights are working. If they are, then the problem might lie in the dimmer switch or the connection going to the dimmer switch. Dimmer switches are a source of problems in the TR6.
My guess is that the fuse blew and you don't have tail lights either.
Edit: BTW, directionals are on a different circuit.
TR3driver
Great Pumpkin - R.I.P
I agree entirely, except I'd check the tail lights first (easier than trying to meter the fuse). If they are working, the problem has to be between the fuse and the dash lights, which means most likely the dimmer control. They are easily fried and can make a popping noise when it happens.
veale001
veale001
Thanks for the feedback fellas!
It was the fuse. But the question that I didn't articulate properly was the turn light (in the dash) works but the dash lamps do not? Would it still be the dimmer switch?
Thanks again,
Warren
TR3driver
The dimmer switch only controls the dash lights that come on with the headlight switch; gauge illumination and maybe one or two others on the console. It is not involved in the turn signal lamps, high beam indicator and various other warning lamps. So it might have been the problem (if the tail lights still worked).
martx-5
Thanks again,
Warren
The turn light in the dash is part of the directional circuit. That has NOTHING to to with the other dash illumination lights. Same goes for the high beam indicator and the "no charge" light.
veale001
veale001
I appreciate the help guys. The website with the disassembled switch was great help. This place is best forum Ive come across, I owe you a round.
Cheers
W
veale001
veale001
Tripel is such a good style. Doesn't take many...
I brew my own for [censored] and giggles and my Tripel takes at least 6 months to ferment properly. Corsendonk, a brown ale, is one of my favorites. A business partner of mine is from the town it is brewed; Turnhout, Belgium. Im kind of addicted to them now.
Hope yall are all having a good Memorial Day
W
Platinum
Welcome to th' forum, Warren!
Randall and Art are okay guys... but ya gotta watch that "Brosky" fella... :jester: :devilgrin:
mehheh. :smirk:
DNK
I'd get rid of that rheostat and put a picture over it.
jfarris TR2/3/3A Dash Lights Triumph 3
K TR2/3/3A Dash Lights Triumph 3
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A re- solder my dash lights Triumph 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
Marla TR4/4A Led dash lights Triumph 0
P LED Dash Lights Spridgets 1
gbtr6 TR6 LED Dash Lights Triumph 8
B Dash lights fused? Austin Healey 3
J Turn signal dash indicator lights Austin Healey 20
Zitch TR4/4A No dash lights! Or any of the gauges. Triumph 11
C Dash lights Spridgets 14
F Spitfire Spitfire 1500 Dash Lights Triumph 1
I Solution for brighter dash lights? Triumph 14
I Dash Lights Austin Healey 1
K TR2/3/3A TR3 Dash lights:Conversion to green bulbs? Triumph 3
R BJ-7 lights on dash. Austin Healey 4
Ofcalipka Where can I obtain dash lights and switches from. Spridgets 18
Atrus '68 Dash Warning Lights Spridgets 7
Don_R Dash lights Triumph 3
RickB Courtesty, dash & trunk lights - commonality? Spridgets 5
eejay56 85 Honda dash lights Other Cars 6
G TR6 TR6 dash lights not bright enough Triumph 22
RickB Dash Lights - the Good Lucas Fairy has visited!! Spridgets 9
73MidgetLigon Dash lights Question MG 6
B Turn blinker lights in a "pillow-dash" Spridget Spridgets 0
M Dash Lights Jaguar 1
hondo402000 LED Dash lights Triumph 15
S TR2/3/3A Wiring for Dash Lights - TR3 Triumph 6
D TR4/4A TR4 Dash Lights Triumph 7
GlennLBC Midget Dash Lights Spridgets 10
S Dash lights MG 5
S Dash Lights??? MG 9
tahoe healey dash lights Austin Healey 8
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
