Dash Install questions
vette
Looks Good Dale. Keep up the good work, But unless you want to win Trophies don't worry about perfection. It's all in the Drive.
( but of course I suppose you have plenty of time to work on it for the next few months ).
Deleted member 19315
Looks Great Dale, and a useful reference thread for doing mine over the winter. I am using a similar colour leather Martrim Matador Red I noticed my dashboard doesn't have any cut out or feature for heater controls ( which isn't a worry a I don't have a real heater just a coil and blower under the dash) Just wondered why my dash BN4 Longbridge 100/6 would be like that. I'm going to fit a period dashboard indicator switch and horn buttons t do away with the column wiring etc too.
R
RestoreThemAll
I found dash bulbs! Seems crazy to some folks but I live in Nowhere NY. I have to order stuff. Installed the bulbs last night and nothing worked. I tried everything. Went back to the wiring diagram...forgot about that dash light switch out of sight under the dash. I don't know about you guys but for me out of sight out of mind.
I used incandescent bulbs but slightly higher 2.7 watts. Should be OK, right?
vette
When I rewired my BJ7 I eliminated the small hidden dash light switch. It certainly comes from another era and in my opinion is absolutely useless. 2.7 watt bulb on 12 volts will pull .225 amps.
noddy
Hi Chaps,
New to BCF, Not sure what the protocol is but I will chip in anyway. I am restoring a BT7 and whilst fitting the dash found it has no side fittings to attach the dash to. Where are these fitted. What should these look like and how is the dash attached to these. Grateful for any info.
Noddy
vette
Welcome to the forum Noddy. Ya don't have to worry about protocol much as long as you are relatively polite. :smile:
I've found that the bunch on this forum don't trash each other, they just work together.
I will reattach a pic of the side pieces that hold the dash in place. I believe the only other point where the dash is fixed is a single screw with back brace which is near the center of the dash face but not exactly centered.
British_Recovery
Bronze
Noddy,
The parts you need can come from Kilmartin - AH295L and AH295R. They are in Australia and British Car Specialists in California offer the line.
noddy
Hi Jedi warrior,
Many thanks for part numbers. I live in Uk but believe or not parts are easier to come by in the US. I didn’t have the part number. I will try again.
I am also travelling to Australia in 2weeks and know a few Healey owners out there. So I now have 3 options. Again many thanks
Noddy
R
RestoreThemAll
Noddy, do you ever use AHspares in the UK? It seems like they are closest to you.
If you don't find a part on their web site then call them.
Dale
longbridgehealey dash top install Austin Healey 0
DNK Dash install Triumph 9
S BJ8 Dash install tool? Austin Healey 5
G Install Bugeye dash in my 67 Midget Spridgets 0
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
