Dash install
DNK
Do I really have to take the big gauges out of the dash to install it when the steering column is in and no wheel?? /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
Ab Crevoiserat
Yes you do, but it only takes about 1hr total out and in.
T
Tinster
DNK-
I had my dash out and on a stand to pre-wire all the lights
for all the gauges. I think I remember installing the dash
as a single unit, balanced on the bottom edge.
Then I hooked up the sender wires and finally the two large cables to the speedo and tach.
I forgot to connect the tiny oil pipe to the oil pressure gauge. It filled the passenger's floor pan very well.
d
DNK
DNK
Dale- Doesn't seem to fit with the voltage thing on the 1 gauge.
RomanH
You have to take the speedo and tach out to remove or install the dash. The retention clips for the big gauges hold on to the back of the steel dash panel not just the wood insert as the small gauges do.
2wrench
I was able to intall all gauges into/onto the refinished
wood dash. I, as well, placed the wood dash on its bottom
edge and pushed the wires through the metal dash holes
connecting them to their appropriate connections on the
guages. Seems to be working fine so far.
A slight crank on the engine did deposit oil to the area
before the oil pressure guage was fully hooked up, so
do remember to connect the oil pressue connections
entirely before turning her over.
T
Tinster
I took the voltage gizzmo off the large gauge.
It can be installed just about anywhere in the tem
gauge line.
d
DNK
DNK
Is this correct?
R Dash Install questions Austin Healey 31
longbridgehealey dash top install Austin Healey 0
S BJ8 Dash install tool? Austin Healey 5
G Install Bugeye dash in my 67 Midget Spridgets 0
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
