Crank and pistons needed near Minneapolis?
My brother in law is restoring my wife's Mini wagon and is looking for an 850 crank and a set of pistons and rings. Anybody have? Would prefer to be in the Minneapolis MN area so he could pick them up but will take what we can get. Thanks guys!
racingenglishcars
They say the 850 was the most produced engine of all, but it doesn't seem like there are too many of them in Minneapolis. It's been 20 years since I had one of them. I wouldn't mind getting one for my 64, but they seem hard to find also here.
What's wrong with what you have?
ooh, could we see some more pictures on you photobucket? :smile:
EricG
I have a complete 850 engine and trans in unknown condition for $200. I am in South Carolina though!
Hedgehog
Wish I could help, but mine are all from 1275s. I'm only 3 hrs from the twin cities should he decide to go up a couple sizes. :smile:
Genos2
I have a set of new(never installed) 5-ring pistons on rods for an early Sprite. I'm in WA, not sure what they are worth or shipping.I could e-mail pics & check size. cheers Genos2
B Good source for Crank/Rod bearings and Pistons? MG 11
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 30
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T Replacing the crank pulley/damper Austin Healey 4
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
R Crank damper alignment Austin Healey 6
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
S TR4/4A Water pump and crank nose questions Triumph 7
GTP1960 TR2/3/3A Removing the fan extension from the Crank hub Triumph 13
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
M Crank Pulley Removal Austin Healey 12
J General TR Narrow Belt crank pulley Triumph 0
