Courtesy light plinth
John_Mc
Here's a low tech question to give you all a rest from the high tech ones: anybody have any thoughts about using the tunnel courtesy light plinth? I'm debating getting one, but wondered if the consensus was for or against. Does it get in the way? Do you have something else that uses/needs that space more ie fire extinguisher, red-vine dispenser, etc? Just curious.
I thought the plinth (love that word) and light were std in TR6's up to/incl 1972. My '73 doesn't have it.
Inevitably when I'm in the TR6 I buy something that won't fit in the boot, I tend to stuff it behind the seats which would probably end up breaking a light mounted there.
I have a '71 TR6 with the factory courtesy light. I think its definitely worth the while since these convertibles of ours are absent any dome or courtesy lighting. The plinth and bulb are fairly substantial items and present a low profile to wayward cargo.
Have one in th '70 TR6 and always glad to see it come on, it means something is working and the battery is good. Wayne
I've said it before and I'll say it again....
Real men don't have courtesy lights...
OR roll-up windows. /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/devilgrin.gif
[ QUOTE ]
[/ QUOTE ]
HaHa, I like that one Wayne!
It is always with trepidation that I approach the LBC.
[ QUOTE ]
[/ QUOTE ]
It's taken man thousands of years of progress to come up with the electric light and Jim has just hurled us all right back to the stone age. /ubbthreads/images/graemlins/jester.gif
Thanks Jim!
B TR6 Courtesy light switch Triumph 1
B TR6 Courtesy light switch Triumph 5
I TR6 TR6 courtesy light wiring help Triumph 26
AUSMHLY Healey courtesy light...another bright idea Austin Healey 43
G MGB 1978 mgb courtesy light needed MG 1
G MGB Courtesy light for 78 mgb MG 4
T T-Series Courtesy Light Door Switch MG 2
S TR6 tr6 courtesy foot well lights Triumph 10
FlyingCat Spitfire Courtesy Lights Triumph 2
I TR6 69 TR6 courtesy liight wiring help please Triumph 5
Lin Interior Courtesy Lights for BT7 Austin Healey 1
G MGB 78 MGB courtesy lamp MG 5
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
D TR2/3/3A 3D printed tail light Triumph 12
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
B Positive-Ground LED Light Strip Austin Healey 8
bigjones TR2/3/3A Rear tail light not budging Triumph 5
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
F TR2/3/3A head light buckets Triumph 3
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
G Brake Light Switch Failure Austin Healey 24
J TR2/3/3A Red ignition light stays on Triumph 7
Chrisc9 TR6 TR6 brake light Triumph 6
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
C MGB-GT Reproduction light switch MG 13
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
T Tail light extension Spridgets 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
6 E-Type brake light pressure switch location Jaguar 5
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
R side light install Spridgets 2
S TR6 Oil Pressure Light Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Cappy Ignition Warning Light Austin Healey 6
I TR6 Dash light issues Triumph 19
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
B Brake light weirdness Dodge Ram Other Cars 5
JPSmit I saw the light! I saw the Light! Restoration & Tools 19
P TR2/3/3A TR3B Panel Light Switch Triumph 20
D TR2/3/3A center panel indicator light color Triumph 10
