Contact Cement Go Away
ekamm
So starting to work on my TR3A cappings and need to know the best way to get the original vinyl off. I am assuming that they used a contact cement. What's the best way to remove both? Should I try to get down to bare metal? Will the new adhesive bond if I don't?
DougF
A good solvent should take care of the contact cement or other adhesives. It might take a little time, depending on how much adhesive was used.
toysrrus
Howdy Eric,
Definitely get it down to Bare Metal. If all else fails; Throw some heat on it of sorts.
Regards, Russ
CARSINC How to remove factory contact cement? Spridgets 9
RAC68 Professional Trim and Upholstary Contact Cement Austin Healey 4
S TR2/3/3A Contact cement for vinyl Triumph 6
Tinkerman TR2/3/3A Removing old contact cement Triumph 6
Tinkerman How to remove dried on contact cement? Triumph 11
Tinkerman Fun With Contact Cement On My Dash Triumph 2
ekamm contact cement use Triumph 7
CraigLandrum Weldwood contact cement oopsie Triumph 28
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
Michael Oritt Brake pedal contact or mercury switch Austin Healey 19
TR4nut TR2/3/3A TR3/4 Water Pumps - Anyone have the ebay rebuilder contact info? Triumph 5
T Wheel rim corrosion at tire bead contact Austin Healey 1
TonyPanchot Art Lipp Contact Triumph 3
T Guys - contact me before bidding on Tr-man items Triumph 13
Newkie running lights contact or lack of? MG 2
mccalebr Trying to contact Jeff Dahn [Bugeye58] Spridgets 4
Gray_Cat Morrisservice Contact Spridgets 4
angelfj1 Personal Contact at Moss Motors Triumph 6
jlaird contact Bud direct via emale Spridgets 5
1965_MGB MGB MK1 MGB Horn Contact Question MG 0
emann BE horn push contact too long? Spridgets 8
Michael Oritt Kendall Jones contact info Racing 3
bcliff Contact info for Gaston [the dash guy] Triumph 16
jaybird MGV8 & MG2006 contact list MG 0
C Hub Rebuilder Contact? Triumph 0
Alfasudcrazy TR6 TR6 contact breaker points - closing Triumph 3
T CONTACT Sunbeam (Rootes) 1
Editor_Reid MGB-GT Want to Contact MGB-GT V8 Owners MG 9
J Contact OL Oxidation Solvent Restoration & Tools 0
KVH Dash Cement Triumph 1
P Jag XJ8 starts but then dies right away. Jaguar 4
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
lram59 TR4/4A Hide away relays Triumph 2
F TR2/3/3A RULE#1 Never throw anything away Triumph 3
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
S TR2/3/3A Don't throw anything away. Triumph 7
R Clutch Went Away Austin Healey 9
S TR2/3/3A holding the paint gun away Triumph 4
O Hesitation on pulling away from stop Jaguar 25
D never throw old parts away.... Austin Healey 7
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
F Throw away BN7 Gas tank Austin Healey 3
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
Bob McElwee Rode Hard and Put Away Lovingly Austin Healey 6
PAUL161 MGB This is what I gave away! MG 14
T Moss Hide-away amplified aerial part no. 230-555 FORUM Navigation Questions 1
