Confused by digital timing
ncbugeye
Being an old-fashioned guy I find these new-fangled digital timing lights rather initimidating. The instructions do not seem to make sense, perhaps they were written by someone for whom English is not the native language.
I have the Actron Digital CP7529 which I purchased from PepBoys, OK, OK, OK, everywhere else was totally out of stock just before Christmas. It has a whole array of buttons on the back and a little display.
Can anyone please, in the context of a Bugeye with a 1275:
<ul>[*]remind me how to set the base timing initially, it has been well over 30 years since I last did it
[*]provide me with a simple set of instructions on how to set the centrifugal advance with this Actron gun thing, and possibly check out the vacuum advance to see if it is working OK. Do I need a vacuum pump?[/list]For a start I have noticed it is d**n near impossible to get to see the timing marks on the crankshaft pulley.
I would be ever grateful.
Dave Russell
Yoda - R.I.P
Hi Chris,
I tried to use one of the very same lights, for the same reason. They are a complete joke. It's got more junk on it than anyone needs & it doesn't even work reliably. In the instructions they warn you (small print) to use a resistor core wire on the #1 plug. Even when following directions it jumps from one mode to another & is wildly inaccurate. It's now in the junk pile.
Went back to my very old but reliable Sears model 213400 (1963) & have had no trouble since. I suggest you beg or borrow a known good timing light before going any further. There is a lot to go wrong with the "dial back" timing lights & it's important to get it right.
dklawson
Thanks for the information. I'd considered buying one of these a while back.
I bought a cheap Innova 3568+ at a swap meet. It was "dead on" according to my dad's "tried and true old blue" timing light. I've only used it about a dozen times, but it seems to work well and only four buttons on/off, strobe on/off, +adv, -adv.
It shows the rpm and adv simultaneously on large LCD.
jlaird
Sears model 213400 (1963)I have one of those as well, works great. could not have been expensive or I would not have it from back then.
Jim_Gruber
I also got a new Timing Light for Christmas. Need to come up with some sort of pointer and reference that is 180 degrees off maybe mark the reference pointer with white nail polish or something like that.
As I understand using the dial back timing lights.
Adjust dial scale to zero.
Connect and fire up engine
Set timing at idle speed, whatever that is in a Spridget.
Speed up engine speed to X RPM
Readjust dial scale so that timing marks show as zero.
Scale will indicate what type of advance you are actually getting at X RPM.
Haven't taken the Timing Light out of the box yet. Getting too old to crawl under engine to use. Have timed strictly by ear so far.
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
JimTR4 TR4/4A Coil - easily confused... Triumph 6
catfood Confused... again! Austin Healey 2
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
Trevor Jessie Confused about top down driving weather [off topic] Spridgets 43
DNK TR6 Well I'm a Little Confused Triumph 4
G MGB I may be confused :[ MG 5
J Confused about Bugeye windshield to body seal. Spridgets 15
JPSmit Need a MOWOG and very confused Spridgets 13
N TR2/3/3A Confused TR3A owner Triumph 5
KLUTZ Confused with my Overdrive wiring.. Help please MG 3
G Confused about the oil separator Triumph 7
1 a confused idle Triumph 8
jjbunn Confused about stalks Triumph 5
drooartz I've confused myself -- timing questions... Spridgets 3
L Spitfire Bit confused by my Spitfire coil wiring... Triumph 10
timbn2 confused on tranny covers.... Austin Healey 7
10musketeer Confused with starting/ignition/timing Spridgets 63
bravenrace I'm Really Confused TVR 13
KLUTZ Now I am confused, Re: Filler. MG 40
jjbunn Confused about gear stick/shift knobs MG 14
R TR6 Confused over TR6 Engine Number Triumph 5
G Now I am really confused.... Triumph 2
prb51 TR2/3/3A Tr3 conFused Triumph 7
daddytiger64 Confused... Sunbeam (Rootes) 9
69MGC T-Series MGTA Digital Painting 2 MG 0
69MGC Latest Jaguar Digital Illustration Jaguar 0
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
69MGC Ferrari GTO Digital Illustration Other Cars 0
SD Bugeye Going digital Spridgets 4
S TR4/4A voltage regulator - digital Triumph 13
P TR4/4A Digital Shop Manual for TR4A???? Triumph 2
R Need digital photo of grill fittings Austin Healey 5
A MGB digital gauges for mgbs MG 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
