Confused about Bugeye windshield to body seal.
Jimflorida
I read a couple of posts that had pictures of a wide seal that seems to go under the Bugeye windshield frame where it sits on the body. The only thing that I see listed in the catalogs is a small seal that I believe goes directly under the windshield frame. The pictures seem to show a extra seal that is wide. Are the two seals under the Bugeye windshield frame?
jlaird
Only one for windshield to body. For BE Moss 680-870
J
Jimflorida
Thanks, Jack. That makes it a lot easier. it's not like I 'm going to do a lot of driving in the rain anyway.
I think the seal for the 9-stud windshield is different. Be sure you have the correct seal.
jlaird
All Bugeyes are the same for windshield to body seal.
The_architect
I believe that Trevor is referring to Moss's part number 680-875 windshield to body seal for BEs up to 5476.
The replacement seal I put on last summer, which is the 680-870 that Jack mentioned, seemed to extend toward the front of the car maybe 1/4 inch or more toward the front of the car than the original. I had to trim a bit around the windshield wiper bezels, but when it was all said and done it looked great.
Think I used something like a butter knife to pry it into place--it went in just a tiny bit at a time--and a lot of dishwashing liquid. It took a lot of time. Gather your patience together it is a powerful tool.
Charlie
Correct Charlie, NOT ALL bugeyes use the same windshield to body seal.
smaceng
the other hint I can give to installing the gasket is to flair the end cuts out toward the front of the car. I cut mine square, and there is a small void next to the pillar attachment to the body at the front.
Scott in CA
StarkM
Here is a photographic illustration of the differences between the 2 BE seals.
The BE had a different glass frame and pillars from (c)5477 on which deleted 7 of the hood (soft top) fasteners.
680-875 is the earlier (c)501-5476
680-870 is the later (c) 5477-on
Photobucket
Photobucket
Hope that helps.
J
Jimflorida
Thanks for the pictures, Matt. It seems that I have the correct part for once. Jim
HAN8L1965
When mounting stick a wooden tongue blade under the seal and move it along across the length of the frame, it will help flatten the seal out and keep it from not laying properly and not scratch your paint.
Mark
nomad
I rolled the front lip of the seal under to get a good windshield to body seal. Also a little clear silicone sealer carefully applied stops the leaks. There is a thin clear silicone windshield sealer available under the brand name Permatex. VB advertises it but your local auto parts store can get it if they don't already have it.
Kurt.
jlaird
Oh my goodness, the front lip seal is suppose to be out/forward. No sealer should be necessary at all.
nomad
Agree Jack, but my car is'nt as nice as yours. PO installed the windshield and rolling the seal under seemed to be the best way to seal it. The glass is pretty good but glass to frame seal is original and car came from So Cal smog exiistance. The rubber around the glass is hard as concrete and has cracks in it that would allow little steams of water to run down the inside in a rain. The Permatex thin silicone stopped the leaks and made the rubber actually look like rubber again. Also sealed up a couple other small leaks and is'nt really even visible unless you look close.
Kurt.
jlaird
Ahh, misunderstood, that sealer is great glass to frame. In fact we used it a lot back in the 60 and 70s for that same purpose. At the time came in a very liquid form.
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
JimTR4 TR4/4A Coil - easily confused... Triumph 6
catfood Confused... again! Austin Healey 2
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
Trevor Jessie Confused about top down driving weather [off topic] Spridgets 43
DNK TR6 Well I'm a Little Confused Triumph 4
G MGB I may be confused :[ MG 5
JPSmit Need a MOWOG and very confused Spridgets 13
N TR2/3/3A Confused TR3A owner Triumph 5
KLUTZ Confused with my Overdrive wiring.. Help please MG 3
G Confused about the oil separator Triumph 7
1 a confused idle Triumph 8
jjbunn Confused about stalks Triumph 5
drooartz I've confused myself -- timing questions... Spridgets 3
L Spitfire Bit confused by my Spitfire coil wiring... Triumph 10
timbn2 confused on tranny covers.... Austin Healey 7
10musketeer Confused with starting/ignition/timing Spridgets 63
ncbugeye Confused by digital timing Spridgets 5
bravenrace I'm Really Confused TVR 13
KLUTZ Now I am confused, Re: Filler. MG 40
jjbunn Confused about gear stick/shift knobs MG 14
R TR6 Confused over TR6 Engine Number Triumph 5
G Now I am really confused.... Triumph 2
prb51 TR2/3/3A Tr3 conFused Triumph 7
daddytiger64 Confused... Sunbeam (Rootes) 9
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
