California YOM licence plates
rusty55
So, The TR3 is now complete. The car was completely restored using parts from 3 separate TR3 cars. The TS# matches the registration. The car was last registered in another state like 12 years ago.
I have the proper yellow plates for a 1960 vehicle that I picked up years ago. The car has never been registered in my name or in CA.
Anyone have any ideas how to begin the registration process short of spending countless hours wasting away at the DMV?
Any help (ie; secrets) would be great.
Thanks
DNK
Cash is helpful!
AngliaGT
I think that you're better off to just go to
the dmv.That way,if there's a problem,you'll know about
it right away,& you can get the ID number verified also.
- Doug
TR3driver
Great Pumpkin - R.I.P
I'm afraid there is no other way; AAA won't help.
First get on the Inet and find the DMV page about YOM plates. Print it out, make sure you have met every item. Don't forget, you need the 1960 sticker.
Take the car with you, if you have a trailer (best not to drive it there the first time, although I have gotten away with it in the past). Even without the car, take the plates and your checkbook. Hit the Torrance DMV about 4 or even 4:30 PM on a Thursday. Not too busy then, and the closer it gets to 5 PM, the more motivated the clerks become. If you don't have a trailer, be sure to ask for a temporary registration, so you can take the car to them for VIN verification. Take a book or newspaper to read, it helps the time pass.
I had relatively little trouble with registering my 56; the only real hassle was because I wanted to keep the black plates (which don't qualify under the YOM program for my car). But it still took several trips over a 2 or 3 month time span.
AngliaGT
You can also make an appointment at DMV.
And,like Randall said,take a newspaper,magazine,
or book with you to read.
- Doug
6TTR3A
<span style="font-size: 11pt"><span style="color: #003300">Also, just to make sure your yellow plate number isn't in use (same sequence as black plates issued later), call the CA DMV License Pate Verification Desk..
1-800-777-0133, option 1 (english), 0 for agent....They can give you immediate verification.
Frank </span></span>
smaceng
Make sure you have two of the subject plates and a 1960 sticker as mentioned above. Also, I had the local police dept. verify the VIN, when all I had was a tub, no engine, no wheels, and no interior, but I did have a speedo in it just in case he wanted the odometer reading. I had pictures just in case when I went to DMV amd lucked out with just two visits. In my case I ordered personalized plates "60 FROG". Good luck.
I did not have prior registration, but had a CA bill of sale from the PO and the one before that.
Scott in CA
R
rusty55
Great. Thanks for all the info. The plates match and are in great shape. The 1960 sticker is missing but it seems I can purchase one from eBay.
https://www.ebay.com/itm/1960-california-...=item53dbb4a0ad
The 1960 stickers have a serial # on them. Does anyone know if that serial # is in anyway tied to the plate #???
I just want to get it all worked out before I get in there and find out something isn't legit.
I'll call and check the plates are clear tomorrow.
TR3driver
They record the sticker numbers now AFAIK; but the old sticker number for your plates (and whatever year they were last registered for) should be gone from their system by now. They only keep inactive records for 3 or 4 years now, to cut down on the database size.
Be sure the sticker is on the plate when they see it though. Reproductions are technically illegal.
Bob_Muzio
I did the YOM on my TR4. I was lucky, it was a breeze. You might also consider bringing photocopies of the plates. Definitely make an appointment unless you enjoy "people watching".
Bob
PatGalvin
I know you are talking about old plates, but what does "YOM" stand for? Sorry, I'm acronym-challenged. Took me a year to figure out LBC....
TTYL,
Pat
smaceng
I would bring the plates and the sticker to the DMV. I am told they will check to see if they are real...in this case made of steel and not aluminum...like the copy cat vendors use. Here is a picture of what it could look like on your car. This is a special license plate holder designed for the YOM plates. Scott in CA
cheseroo
Went through this last year with the TR250. Finally got registration stickers about 5-6 months after the process was started. It goes a ton easier if you have old DMV paperwork with the plate numbers on them but that wasn't the case for me or apparently you. MUST have both plates. Wasn't an issue on this car but be very clear that you are doing a YOM registration and do NOT want new plates issued. Once they issue new plates, it starts you on a different path that you don't want to go down. Make sure you get the repro stickers in hand before making your appointment. For whatever reason the oldest sticker on my car was 1969 so I bought one of the ebay stickers (68 model year car/plates needed a 68 sticker). I think they put their 4th grader in charge of making it. To disguise it's cheesyness, I heated the old stickers on the plate and carefully removed them. I put the ebay sticker on and stuck the old sticker stack on top of it so we could do an archeological sticker dig with the DMV clerk as a ruse to make the cheesy sticker look more authentic. They bought it. I have had good luck going to the DMV in the 9:15 to 9:45 time frame. By that time they have worked through the big line of people standing outside the door before opening and the pre-lunch crowd hasn't arrived yet. The last couple times they called my number almost immediately.
R
rusty55
Thanks everyone. Hopefully all goes well. I'll post back when completed.
GilsTR
We did this project last year with a 1931 Ford Delux Model A Roadster. Got real lucky and found really nice 31 plates.
only had a bill of sale to work with. What we discovered was different DMV offices take a different track on this issue. We talked with different car guys...and found the
DMV office a half hour away was where we wanted to be....
BINGO! Half hour and our 31 Model A was all set with these plates. Good luck to you. Gil NoCal
R
rusty55
AMAZING!!! Lets hope it's that easy for me too :smile:
KVH General TR 500 Miles Arizona to California Triumph 12
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
69MGC MGC Any recommendations for a good MG restorer in California MG 26
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
Michael Oritt Conclave 2021 in Southern California Austin Healey 16
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
SCguy New British Car Repair Shop in Northern California, Sacramento, Auburn, I-80 Restoration & Tools 2
Rob Glasgow California Healey Week Austin Healey 9
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
D Great Gas Mileage in Southern California [Circa 1960!] Austin Healey 3
M TR6 Inspection services in California San Jose area? Triumph 6
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
S For Sale FOR SALE BN1 100-4 Healey Perspex Side Screen windows [California, USA] Austin Healey Classifieds 2
69MGC MGC VIN Verification in California MG 4
5 Legacey California License Plate Spridgets 1
steveg California Healey Week in Yosemite Austin Healey 9
Bob McElwee California Cruzin Question Austin Healey 6
stretchit2 Southern California Austin Healey Association 40th Anniversary Gathering Austin Healey 3
DanLewis Treasure Trove of Spridget Parts available in S. California [NFI] Spridgets 0
DanLewis California License Plate "BUGS EYE" For Sale [NFI] Spridgets 0
NutmegCT Mark I in California Jaguar 5
J Wedge Modified TR-8 in California...I need help to pass smog...HELP!!!! Triumph 25
J Hey, Northern California Healeys Austin Healey 0
tr6nitjulius Southern California Healeys Austin Healey 5
J Need race cars for a show in Northern California Racing 1
NutmegCT No title, registration in California? Triumph 10
bugedd For the Northern California people Spridgets 0
mgedit VIN Mystery - California Black Plate Triumph 8
apbos TR2/3/3A California TR3 Hot Rod Triumph 3
TR6BobNF TR2/3/3A 1954 California Blackplate TR2 Triumph 14
G Santa found a California Small Mouth ! ! Triumph 10
sjuengst California considerations Austin Healey 12
H Black plates on California car? Austin Healey 2
davester Inexpensive California RB on craigslist-looks good Spridgets 5
Gafirema California Emissions + 1980 MKIV 1500 Triumph 251
G Wedge TR 8's popping up in California Triumph 3
doates California Plates Triumph 30
M MGB-GT New guy from California with a GT [pics] MG 13
Johnny Barn Find in California.... Austin Healey 18
J Hello Contra Costa County California MG's MG 0
NutmegCT Anyone near Santa Maria, California? Triumph 4
NutmegCT anyone near Santa Maria California? Other Cars 0
C British Wire Wheel, Fresno California Austin Healey 5
jsfbond Brits in California Triumph 3
M MGB Buying a MGB from California??? MG 15
B Head work in California Austin Healey 2
skinsgamer Running Rich in California Spridgets 23
K Anyone here live in Costa Porta California? Triumph 4
J So. California Engine Builders Austin Healey 1
