BT-7 tri-carb Two more questions
  • Thread starter Deleted member 21878
  • Start date
1) can i get the front pipes on after i have installed the heat shield and tri-carbs?
2) should the caps on the HS4 carbs be vented?
Thanks
Healey Nut
Anything is possible it just depends how flexible your wrists are and how extensive your tool collection is .
As for the carbs .
I have an original unmolested set all still in one piece in my shop for my 62 tri carb project . I will have a peek tomorrow.
elrey
If you mean the caps on the float bowls, yes, they are vented. The stock vent tubes are clear with an interior spring at the bend. They just bend straight down a couple of inches and stop. Some folks rout the tubes to the side, but many are left stock. Some folks omit the vent tubes entirely. I solved the periodic venting problem by switching from conventional valves to the Gros-jet ball bearing valves. If you retain the stock setup I believe Delrin (or some such) needle valves are required due to the makeup of fuels sold today.
i was asking about the damper caps. i have always read that when SU carbs have that angle brace at the top of the carb, they do not use a vented cap. My caps are vented.
elrey
I am not sure....The assumed to be stock damper caps on the HS4s on my side shift tri-carb are not hex edge brass like the caps on many other S.U.s. They are dark plastic fluted edge affairs with a definite vent hole off center. I have seen these caps on most of the tri carbs. (but I never thought to look for the hole, I was more enthralled by the fluted edges.)
blue62
Drone Dog
If your carbs have internal venting (Called dustless venting). Then you do not want vented caps.
My understand is that if you have both the piston will not raise properly and you will be chasing all kinds of mixture problems.
Hope this helps.
Thanks. vented are all i have seen. i was just wondering because of what i read when working on the TD.
elrey
Thank you Maestro Brinkerhoff, it is good to have to have the benefit of your expertise.
Healey Nut
Pic of my unmolested tri carb set up . Breather holes in all the caps . 1/16” ish
elrey
Just like mine. Designed to be operated with thumb and forefinger. I can hear the sound they make when you check them just by looking at the picture.
John Turney
Are all plastic caps suppose to be vented? I have HD8s, and the plastic caps had been molested. A PO glued dimes on top. I took the dimes off, but can't tell if there were vent holes.
Lin
This discussion about vented versus non-vented damper caps got me curious. I wrote Joe Curto and heard from him right away. I also found a website authored by a fellow who has SUs on his Volvo. The bottom line is if the dome (dashpot) is vented, then the damper cap should not be. The reverse is also true. If the dome (dashpot) is not vented then the damper cap should be, that is, it should have a hole in it. To see if your dome(dashpot) is vented, just unscrew the damper and look at the inside neck of the dome. If you see a hole, then it is vented. Check out the link to the Volvo website. He provides good captioned photos. Hope this is helpful.
https://65brick.blogspot.com/2009/04/carbs.html
Lin
steveg
Since my HD8s are unvented internally and have no holes, I propose to drill holes. I have a spare, junk, HD8 with a black plastic cap with a 1/16" hole, marked AUC 8114.
Could someone with a stock BJ8 confirm whether they have AUC 8114 vented caps?
Thank you.
bluegrass john
My stock aud 124 HD8 carbs have auc 8112 dampers which are vented; according to the su website and other su publications i have in my possession the 8112 are correct for an Austin Healey Mark 111. The auc 8114 damper is listed on various hd6 carbs installed on other applications. Hope this helps!!
John
Lin
The damper for the HD6 carb is slightly shorter in length than the damper for the HD8. Perhaps someone can chime in on the impact of using a shorter (or longer) damper has on the functioning of the carb.
Lin
red57
The dampers are sized to the carb - if you used an HD6 damper in an HD8 they wouldn't be submerged in oil as well and if you used the HD8 dampers in a HD6 it could prevent the piston from rising fully. BTW, the damper rods are a press fit into the caps - I have triple HD6 now but when I had twin HD8s I used brass caps because at one time I was testing heavier oil and found the rods pushed thru the plastic caps and stuck out the top which led me to pressing them into brass caps, I later went back to lighter oil but kept the brass caps because I prefer the appearance of the brass.
Dave
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
Healey Nut Tri-Carb Project Austin Healey 213
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
