The rubber compounds made in countries other than Britain are not taken into consideration in my rebuttal, true. But, there is a reason. In my extensive research about this very hotly debated topic, the rubber compound issue was addressed by Lockheed ia an article I read on the internet 3 years ago where they specified the elastometer in British rubber components as non-compliant to silicone fluid. Moreover, when the issue of spongy pedal and off-gassing causing unpredictable no-brake conditions is factored in, and the fact that if the master cylinder rear seal leaks into the booster cavity (which is fairly common) and silicone fluid is burned in the combustion chamber, it is bye-bye engine because silicone reverts to silica, which, when burned abrades everything in sight, I absolutely will not use the silicone.
Given the cost of the fresh engine as opposed to the cost or inconvenience of flushing glycol every 2 years, I'll take the glycol fluid. LBC's aren't Toyotas, after all!
They must be looked after constantly!
And, Basil, saving the paint becomes a moot point if you wrap that gorgeous E-type around a tree because of a sudden loss of braking, anyway! :shocked:
