Brake Pipes in Australia
Simmo
To my dismay I just imported a set of very nice Automec Brake Pipes for my 3A and I find that anything other than steel pipes are illegal in this Country of ours.
I guess some highly knowledgeable Public Servant made that profound decision many years back.:mad:
TR3driver
Great Pumpkin - R.I.P
Steel brake lines are always plated for corrosion resistance ... if anyone asks, just them that yours are plated with a new lead-free alloy that contains copper. The original plating contained lead, which contaminated the environment.
mezy vauxhll brake pipes Other British Cars 0
nevets BN6 rear brake pipes Austin Healey 15
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
F Advice replacing flexible brake pipes on BT7 Austin Healey 3
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
Jim_Gruber Brake Pipes -which one to order Spridgets 32
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
middie Flush out brake lines/pipes Spridgets 13
1 Brake and Fuel Pipes Spridgets 7
heliguy Copper or Copper Nickel Brake Pipes? Triumph 4
R Brake pipes; steel or SS Austin Healey 10
T Brake Pipes Part 2 Triumph 25
tr6web TR6 Brake pipes TR6 Triumph 5
G Copper Brake Pipes for MIdget Spridgets 3
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
