Bolt Size Question
1965_MGB
Aren't most of the bolts on our cars UNF? I have seen very few SAE bolts that were not from a DPO on my car.
Nunyas
what about the windshield bolts..... I seem to have only 1 holding it down on each side...
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
GeorgeC BN1 bolt size Austin Healey 0
MY66AH Bolt head size Spridgets 2
K TR4/4A Clutch pressure plate bolt size? Triumph 1
K TR2/3/3A Gearbox bellhousing to motor bolt size? Triumph 12
S TR2/3/3A starter bolt size Triumph 4
R TR2/3/3A Floorpan to frame bolt size Triumph 4
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
Geo Hahn TR4/4A Crank Bolt Size Triumph 5
tri_carb_healey drain plug bolt size 3000 bt7 Austin Healey 6
Newkie Center Console Bolt/Screw size? MG 1
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
doughairfield Bolt size for the bonnet Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Fan Extension End Bolt Size Triumph 20
A TR2/3/3A TR3 generator mount bolt size Triumph 4
H TR2/3/3A TR3 Generator Mounting Bolt Size Triumph 5
N TR6 Bolt size for TR6 Drive shaft? Triumph 6
neilh Cd150 Carb bolt size Spridgets 5
S Front pulley bolt size? Spridgets 2
jhorton3 Bolt Size for Hood Spridgets 6
T What size bolt to secure handbrake assembly? Spridgets 12
Cain Wiper Motor Bolt Size Triumph 0
KLUTZ Bolt size for splash panels? MG 5
D bolt thread size 100-4 Austin Healey 1
V8Blazer bolt size? MG 0
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
B TR4/4A Starter dog bolt Triumph 15
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
W Wanted Bolt on luggage rack Triumph Classifieds 4
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
