body number
dh100m
Member
I have a 69 s2 which over the last 15 yrs have been working on I carefully put my vin plate in a safe place I moved and that safe place is gone .
I have located all numbers except body # and yes I replaced the rear tub from martinrobey.
Is there any other place this number is located and what is the pillar number tr9940 mean
Regards tony :concern:
Deleted member 8987
For sure a 1969 XKE Series 2, right?
Stamped on radiator support?
These are the ranges:
  • 1R1001 - 1R1776: RHD Open Two Seaters (775)
  • 1R7001 - 1R14853: LHD Open Two Seaters (7,852)
  • 1R20001 - 1R21071: RHD Fixed Head Coupes (1,071)
  • 1R25001 - 1R28786: LHD Fixed Head Coupes (3,785)
  • 1R35001 - 1R36041: RHD 2+2s (1,041)
  • 1R40001 - 1R44287: LHD 2+2s (4,286)
Possibly located on the top right end of the Picture Frame about 25 to 30 mm back from the top right hand shock absorber mounting. You may have to scrape the paint off down to bare metal in order to see it clearly.
There should also be a Body number, these were sometimes mounted on the right side of the vertical bulkhead panel but sometimes in other locations.
The number located on the front shock tower that should match the number on the windscreen post.
You asked what the TR9940 number on the windscreen post is.
THAT is the body number you are seeking, and it's most likely an 1R 9940:
Geo Hahn
Alas, the number on the picture frame and elsewhere are the car number (e.g. 1Rnnnn).
The body number would be something like 4Rnnnn and was recorded on the data plate and also a tag riveted to the rear panel to the right of the license plate. The OP replacement of rear panels apparently removed that.
The body number on mine was also written (just the last 4 digits) in a couple of places using yellow crayon. But those marks were not consistent and often go missing through the years.
A build certificate will show all numbers but usually they will only issue one using the numbers you provide - numbers you do not provide or are wrong will be left blank. This is to keep someone from obtaining a picture frame and building a car to go with it.
Here is the form for a research request, they also do the heritage Certificate: https://www.jag-lovers.org/jdhtform.htm?nuc=1
The dollar amounts on that form may be out of date so an email is best initial contact.
It is just possible an email to Gloria or Mike explaining your situation might get you dispensation for the missing number.
Mike's email (last time I corresponded with him) is: mcook69 at jaguarlandrover dot com
The tag you see on the pillar is also the car number, apparently 1R9940.
dh100m
Member
thank you for your response I received my heritage certificate today and body # 4r4196 all numbers match now need to get body tag
Geo Hahn
...all numbers match now need to get body tag
In case you do not know, what it looks like:
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
X Production year based on body number ? TVR 3
M TR4/4A Is there a difference between the "Body" number and the Comission Number? Triumph 8
Rut TR4/4A Engine number and body plate Triumph 5
J Question on 61 AH Sprite body number tags. Spridgets 8
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
5 3000 body number Austin Healey 0
Editor_Reid Body Number Plate Replacement Austin Healey 13
Jim_Newman Body number plate? Austin Healey 6
richberman Why doesn't body number match BMIHT Austin Healey 7
S BN2 Body Number Question Austin Healey 2
M Bugeye body number Spridgets 4
Atrus Car [Vin/Engine/Body] Number help... Spridgets 14
martx-5 Body & Commision Number Plates Triumph 20
E Body Number Triumph 6
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
