TR3driver
Great Pumpkin - R.I.P
Not just #4, but all of them! What i do is wrap a clean shop rag around each journal, and hold it with a twist of wire while you clean out the water jacket.If you have to remove the #4 liner get ready for about a half cup of small rock and sand-like material to drop on the #4 rod journal of the crankshaft.
After the liners ate in place, turn the crank so the journal is at the bottom before you remove the rag n wire. That leaves the oil drilling facing down so nothing can fall into it, while you clean up the area with another rag n solvent.
