BJ7 Carpet Install Questions
P
PeterB
Sorry for the late post, about 1/8” or less.
P
PeterB
Yes, I already used it in the toe box area. The only other pieces I got goes under the front floor carpet which I still have to install. Did you get something different?
Patrick67BJ8
I got the same jute material. I did have to fit it so the snaps would work properly. Do you need photos of that work?
Patrick67BJ8
If you would, that would be great. Thank you
Here's a layout of where your carpet snaps are located on the floor. If you already have the snap holes you're in good shape. The trans tunnel will also have Snaps, hopefully still in place. I added extra Snaps to make my carpet lay down better and used the original brass rings with the securing ring that has the three ears on it to secure the two Snap pieces together.
Concerning the jute that lays over the floor Snaps: Place it as best as you can with equal space around its perimeter. You'll see "bumps" from the Snaps showing in the jute when you apply a little pressure. Cut a square hole in the jute where the Snaps are and the jute will lay flat. Because the jute is so thick that Heritage supplies you would get a depression when you try to Snap the carpet in place. I made small round pieces out of tempered hardboard to to raise the Snap to take care of the depressions. You can use metal washers too.
When marking where the Snaps go on the carpet, I learned this trick from Carroll Phillips...After the floor Snaps are attached to the floor and the jute is in place take the carpet and apply masking tape to the backside of it in the location of the Snaps that are attached to the floor. Lay the carpet in position and with a rubber mallet, or another tool that soft, lightly tap the area where the floor Snaps are located. After doing that, remove the carpet and turn it over and you should have a round impression where the floor Snap is located. Now you have the locations marked with your carper Snaps go!
The carpet that you left a little long around the floor perimeter will be pretty close to the same height as the jute is and make a smooth flat laying carpet.
Patrick67BJ8
I can't attach the Carpet Floor Snap locations for some reason, file is not too big, and if you send me your email I'll send that to you. The Radius Arm Box attached its self and I can't delete it.
Patrick67BJ8
I am installing my carpet set in my BJ7 I got from Heritage. I bought the Moss video that says for BJ7 and BJ8. Unfortunately most of it I think is for BJ8. I have 2 question so far. 1 is how does the carpet lay behind the seat in the corner where the heel board and and shut pillar meet. Where that little “ramp” section is. It almost seems if a relief cut needs to be made so carpet will lay flat on the floor but then floor will show???? Also what gets put in 1st for best fit, the floor pieces or the transmission tunnel piece. Thx any and all help, especially pictures are much appreciated.
I just noticed that photos 8 & 9 are of my car.
maxwedge5281 1963 bj7 carpet install and mirrors Austin Healey 3
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
