BJ7/8 Convertible Top Issues
HealeyRick
I just ordered a Robbins Stayfast top for my BJ7 during their 25% off sale: The original top that is still on the car has cuts on both sides along the top bows Apparently this was a big enough problem on the early BJ7s that they issued a Factory Service Bulletin on it. The bulletin advises removing part of the tonneau trim rail and it looks like the later cars and BJ8 used a different one to alleviate the problem. They also suggested some changes to the top bows. This leads to three questions
1. Does anyone have a later trim piece they'd like to sell?
2. Has anyone tried the top rail modifications?
3. Do the BJ8's have these same problems with top cutting?
Thanks
  • BJ7 Convertible Top Service Bulletin.pdf
My BJ8 had an (apparently) fairly new, probably aftermarket vinyl top on it when I bought it 35 years and approx. 150K miles ago; no such cuts on it.
Keoke
Neither of my 1966 BJ8 cars have that cut either ?
AN6-TX
'66 BJ8 here - I have similar cuts on the passenger side of the top (none that I've identified on the driver side).
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
AUSMHLY BJ7/BJ8 Convertible Top Austin Healey 34
R BJ7 convertible top boot cover- snap orientation. Austin Healey 8
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
