Big 6 Healey engine builder
HealeyPassion
Guys got a question for the racers.... who are the experts on Healey heads?... names/numbers? I'm considering an "improved" head for my 3L 6cyl... would prefer an improved cast head (I don't think the cost of an aluminum head would be cost effective for my non-racer Healey). Also, would think an effective header system would match up with the improved head. I have to believe the header technology has advanced since the factory race/rally headers.. so would be interested in who has really studied this area of the engine... improved extraction..primary/secondary lengths etc.
Okay, so what I'm hoping for is 20% with improved head and headers... is this unrealistic.
Thanks!!!
Steve
https://stevesaustinhealey.com
dougie
Steve -
As you know the head/valves/valve train all need to work in harmony with the rest of your motor, i.e. cam, pistons, induction system. I found out the hard way with my first race motor build....you can't just start adding performance "gofast"
goodies without having a clear plan ands specific goals.
I did all the porting and polishing on my current iron race head, but I had it flow tested before and after so I had a good idea of where I needed to be to support the race tuned triple 2" SU HD8's and specific cam I run. Then it was to the chassis dyno for further testing and tweaks. So you want a 20% improvement....
In horse power, torque, top speed and where are you now?
I'm sure Richard (BoyRacer) will chime in, we use the same machine shop and dyno facility. He also has designed and produced (small batches) 6-cylinder headers which are the finest I've seen. I run a pair on my '57.
I could PM you the specific shops I mentioned, but it's a slippery slope you're on.
HealeyPassion
HealeyPassion
Dougie, I was hoping to hear from you... your machine looks super impressive (watched the videos). Believe me I do understand that it's a slippery slop. I've slide down it with my C5 Vette... 428 hp at rear wheels..etc. etc. from the stock block 5.7L... other than the lower end everything else is different.
But I digress... with my Healey I have the 6 injector efi dialed in ... it matches the BJ8 cam which Dema Elgin cut to improve the lobe separation just a bit to favor injection... so really don't want to touch that... engine balance is racer level. But.. head is stock as a rock... and stock cast headers (but match ported). The intake manifolds are factory tri-carb chamfered to match the ports. But all in all no improvements in head and headers. So my desire would be to JUST improve the head and headers.
We ran a stock, nice running, recently tuned BJ7 on a chassis dyno... then ran mine.. same dyno. The stock BJ7 put down 98 hp at the rear wheels... mine put down 131 hp. So that's where I'm starting.
Why my desire for 20%??... I went to the Texas Healey Roundup in Bastrop, TX in April... I live at 6,700'.. so it was like getting a free 20% hp boost running at basically sea level. That equates to about 20%... the car felt lighter and more responsive, of course... so I'd like it to feel like that where I live.
Thanks!!
Steve
HealeyPassion
HealeyPassion
Oh, and Dougie, those headers are absolutely beautiful. I'm wondering though if they are more for racing...i.e. high rpm. I'm thinking of something that maintains velocity for mid-rpm response.
Steve
DerekJ
Dougie,
Just out of interest, what made you chose the triple SU's over Webers?
I have a fast road set up with 2 HD8s at present. I may also go to an aluminium head and Race profile DWR cam and would fit 3 carbs. But which carbs? SUs or Webers. I wont be racing just doing hillclimbs and sprints so Im leaning towards the SUs. What are your thoughts and experiences on this. Ive got forged pistons but I dont really see myself going full whack for a steel crank and rods etc.
andrea
Hi Steve
Is really important that your engine must be race balanced, my engine run without needing the front damper-
I have the original flywheel to have one good reply at lower and middle rpm and improved camshaft for street top use(nearest to BJ8 phase)
I have 3 Weber 45 DCOE in the final configuration-
but your injection system will be sure better than my solution
My suggestion is don't exclude aluminum heads- it is easy
to work and have increased heath exchange rate-
ask more information to Lin Rose, that I remember have the aluminium head on his 3000
https://picasaweb.google.com/lh/photo/pZTwRRW5JX0svgWBBWn_ptMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/4nnIjQRLvoPdjiwwTJfes9MTjNZETYmyPJy0liipFm0?feat=directlink
This is my 2,6 engine at the first start -equipped with the
3 Webers- some flames -but increasing the diameter of jets
and changing the electric fuel pump, solved the problem
I have poor fuel supply for the acceleration pump of the 3 WBS
Now the engine run quite- with a glass of water on it- also at
5000 rpm
Cheers
Andrea
EV2239
The camshaft is the only thing that makes 20%, the nest head in the business might give 10% if you were lucky.
You need more revs to get more power and cams do that.
Ash
Superwrench
Check out Denis Welch. They have a cnc ported cast iron head for exchange for yours, or they will do yours. Not too bad a price. They have some nice cams also. If you want more than 20% check out isystemsperformance.com. These guys helped NASCAR get 850 hp out of the small block chevy. Like Dougie says, everything has to work together. good luck
John Turney
:iagree: on the exchange cast iron head. I have DW's aluminum one and several other of his bits. Talk to them and they can help you put together a package that should meet your needs. That's what they did for me.
Can't tell for sure from the photo, but it looks like all 6 primaries go to a single collector; does that mean this becomes (essentially) single exhaust? Or is it just the photo?
dougie
Just the angle of the photo....there's 2 separate collectors.
Steve, I'm reviewing some of my build sheets and dyno runs to see what top end improvements helped the most.
Derek, my goal from the start for my '57 100-6 was to prepare and present a "period" vintage race car as one would have seen in the US in the late 50's and early 60's. It's prepared to FIA GT 2 regulations for production sports cars though, this does allow for Weber's. They didn't allow them in SCCA at the time however, and they governed most of the sports car races in the US. My car can still driven on the street and with the Ruddspeed manifold it has the period look that appeals to me. For true "all-out" performance Weber's would be the best choice, that's just not my intention.
BoyRacer
Power is made in the head, not so much with the cam. Keep your cam relatively mild. You do not want to over-cam the engine. For example, the Iskenderian T-3-6 grind, or something comparable, is perfect for a hot street car. You can find the specs on-line. Do NOT go any bigger with the cam unless you want your power band to be in the 6-7000 RPM range.
Advance the cam. This will give you more low-end torque. Especially since you have now up-rated your cam with more overlap that saps some of your low-end torque. I have offset keys so if you are interested - contact me with a PM.
As for the head, take it to any good, reputable, race engine prep shop and have them do a pocket port and open up the runners. If they do not have a flow bench, then do not use them.
You should replace those odd size British valves with larger American stainless steel swirl valves (less expensive and better quality than stock valves) that have longer stems so you can use good quality American springs (also less expensive) that will allow you to use more valve lift.
The stock rocker arm ratio is 1.43:1. Don't believe the cam grinders that claim it is 1.5:1. A higher ratio rocker will give you the breathing you need to get that 20%. You may need to notch your block for exhaust valve clearance. Contact me with a PM for more info on high ratio rockers.
My iron head race engine, with 11.3:1 compression, higher ratio rockers, a cam similar to the Isky T-3-6, advanced 4 degrees, makes 231 HP at 5800 RPM at the flywheel. Torque is over 200 ft lbs from 3000 RPM to over 6000 RPM. Sorry, we never measure anything under 3000 RPM ...it's a race motor.
If you do some or all of the above, you may need some good headers .... like the ones I make .... that are shown on Dougie's post.
HealeyPassion
HealeyPassion
Hey BoyRacer thanks for chimming in. I've PMed you with some more detail. So, you made those beautiful headers for Dougie!... look beautiful... and, I suspect, work great. These look like they incorporate some modern header techniques. I have to believe that old style works headers, while great in the day, are not the most effecient given what we now know about scavaging exhaust today.
I found what you said about the head extremely interesting! I'll have to check out the specs on the cam. The issue with performance cams and my efi is that injection systems like vacuum, which if I understand it correctly, is generated by lobe separation angle (LSA)... so when Dema Elgin cut my BJ8 cam he pushed the LSA as far as it would allow... engine runs great. So if the hot cam has little LSA, which is common with carb. engines, it won't work well on my engine. In fact, it is my understanding that one of the reasons slapping on efi to a hot cam engine never works out well is the LSA is to narrow to service the injection... results, poor throttle response, etc.
Cheers,
Steve
DerekJ
Thanks for the explanation Dougie, I also want to be able to drive my car regularly on the road so don't want to go too extreme. I like the the triple 2 inch SU set up. I think a lot of people probably switch to Webers when they don't really need to because, lets face it, they look pretty sexy under the hood.
Great comments re the head from Richard. I'll compare the Isky T-3-6 grind to my DWR8. I dont live that far from DWR so I'll have to go up there and have a chat to them. Jeremy Welch built the engine for my car which was owned by a friend of his at the time.
How powerful can you get? Three weeks ago I drove to a sunday afternoon park and show and pulled up next to a scruffy looking 3000. It was Healey blue, last painted about 15 years ago with a scratched, dull, navy blue hard top and filthy wire wheels. I noticed the Classic Marathon and Alpine stickers on the hard top and got chatting to the owner. Over the last 10 years he had put on just about everything you can throw at a Healey and this wolf in sheeps clothing came in at 298 bhp on his last dyno test!
BoyRacer
298 bhp? Hmmmm.
As a long time racer, I have heard many sayings. One of them is: "When the green flag drops, the bull***t stops."
bob hughes
DerekJ said:
That's a fair comment Richard however it does seem that getting close to 300 at the flywheel is where quite a few guys are at over here.
Yup
I can second that, not from personal experience of course but an associate of mine builds them for a living and and races them, and that is what he is getting.
I suppose that you would expect that after spending over £14,000 just on the engine.
:cheers:
BoyRacer
I'm still skeptical. I've been racing a long time. Talk is cheap. Dyno sheets are better evidence. First question I have is: At what RPM are these engines making 300 HP? Secondly, what kind of torque are these engines making, and at what RPM?
We have another old saying here in the US: horsepower sells cars - torque wins races.
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
Dave Russell Big Healey Engine Mounts Austin Healey 10
tlthorne big Healey engine number question? Austin Healey 4
R Big Healey 100 Head Austin Healey 4
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
R Wanted WTB Big Healey Austin Healey Classifieds 3
dougie Big Healey Six - Used the Right Way Austin Healey 5
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
dougie 1963 Sebring Big Healey 57 FAC Austin Healey 4
dougie Big Healey 6 Racer For Sale Austin Healey 2
AngliaGT Big Healey Spotted 0
coldplugs Big Healey near Portland OR Spotted 3
HealeyRick Bugeye Colored Big Healey Austin Healey 0
Marvin Gruber Big Healey brake booster rebuild Austin Healey 4
dougie Silodrome - Big Healey Buyer's Guide Austin Healey 4
Marvin Gruber Big healey coil springs Austin Healey 7
HealeyRick Last Big Healey? Austin Healey 20
Marvin Gruber Big Healey ridged hood Austin Healey 13
AngliaGT Red Big Healey Spotted 0
maxwedge5281 bumperless big healey photos!! Austin Healey 34
Marvin Gruber Big Healey clutch question Austin Healey 3
apbos So Cal Big Healey- can someone examine for me Austin Healey 3
John Turney Another Chance to Own a Factory Rally Big Healey Austin Healey 0
Tronch Big Healey heigth increase Austin Healey 1
maxwedge5281 wtb ubolt plate for big healey Austin Healey 7
HealeyRick Big Healey Tuning Information Memos Austin Healey 0
A Project Small Axe Racing: Big Healey restoration/vintage racer build Racing 30
JPSmit When I grow up I wanna be a Big Healey Spridgets 5
maxwedge5281 differential interchange for big healey Austin Healey 6
dougie Nurburgring in a vintage racing big Healey Austin Healey 3
aeronca65t Big Healey-strange wheels Austin Healey 12
toysrrus "Pickens, SC" resident Searching for "Bernard" in "Liberty, SC" with a Big Healey Austin Healey 0
Gearhead_Garage Big Healey Air Filters Austin Healey 22
maxwedge5281 rear springs on big healey Austin Healey 4
Keoke SS Bumpers for Big Healey Austin Healey 1
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
J E brake help forgo many Big Healey owners Austin Healey 8
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
A Big Healey Restoration Do's & Don'ts Austin Healey 11
DerekJ Big Healey Race - Castle Coombe Austin Healey 10
JPSmit OEW-big Healey Spotted 0
dougie 767 KNX Works Big Healey Up for Auction Austin Healey 4
HealeyRick The Cars the Star - Big Healey Austin Healey 6
Lin Big Healey Roadster Windscreen to body Rubber Seal Austin Healey 0
H Another big Healey coming my way? Austin Healey 3
dougie '56 Big Healey Racer - Racing 7
TulsaFred Help me analyze a potential Big Healey purchase Austin Healey 11
dougie WANTED.... More Big Healey Racers Austin Healey 8
tri_carb_healey big healey salute to fatherhood Austin Healey 9
