Best shop manuals and restorations Guides.
Norton47
What are the better shop manuals and restoration guides for the MGB. I see a restoration guide by L. Porter and a review of that book states the the Haynes for 1962- 1980 is the foundation book. I also see one by R. Williams called Your Expert Guide to MGB Problems. Are these the better books? Are there others?
Thanks
Steve_S
The one manual you must have is the Bentley book. It contains reprints of the factory repair and owner's manuals. It isn't as "dumbed down" as Haynes and some others, but it does cover just about anything you would ever need to do on a MGB.
Platinum
:iagree:
Haynes contains some erroneous info and too many: "Take the unit to an experienced shop" references.
ronzi
I have the Lindsey Porter resto book, the Jim Tyler resto book, and the Bentley manual. The one I always use is the Bentley manual. Seems like the other two spend a lot of print and (bad) pics showing you how to remove a screw on the interior trim, and then gloss over other things that could perhaps use more detail.
If you are going to get ONE, make it the Bentley manual.
N
Norton47
I ordered the Bentley and the Porter and a Williams.
I know the Bentley for the TR6 is excellent.
twigworker
I wholeheartedly agree with all of the above but would add...
In general the best "tools" that you can buy are good references. Certainly until you are very familiar with these cars they will save tremendous amounts of time and frustration.
In the end, even if you end up spending a hundred or even two hundred bucks on them they will be the least expensive investment that you can make on your MG experience, no pun intended.
Get the Bentley manual first and then start accumulating other books, some of which will be more sub-system specific. Any of the Porter or Burgess books will be of value. The Des Hammill books published by Veloce Press will save your fanny some day too. Everything is available at some time or another on eBay or Amazon and can often be purchased as "used", which will save even more dollars.
Also, be sure to stick with at least one if not a couple of good boards like this one. The information exchange is great and everyone is always willing to jump in with their two cents.
Jack
racetearoffs
I found a Practical Classics on MGB Restoration book , not to thick but real informative . Brooklands Books is the publisher // mga ,mgc and v8 , gt , midget .. all models have their own book
brookland books ltd
po box 146 cobham
surrey , Kt11 1 lg england
Dont know if they are still around got the MGb book off fleabay
19_again
For electrical info, nothing compares to Rick Astley's The Essential Manual MGB Electrical Systems. Great pix, explanations. Amazon has it, mine paid for itself the first time I opened it. I agree on the Bentley as well, but you can't have too many. Bentley lacks an index, but when used often enough you get the hang of it.
Mike
Madoc
I found a UK version of the Haynes manual in a local used book shop. It's a dated 1968 and seems to go into a lot more detail than the later versions. Light blue cover with a plastic jacket. It's pretty useful.
WA1KWA
I refer to them all at one time or another. Must have 6 at least. I used the previously mentioned Lindsay Porter 'MGB Guide to DIY Restoration' as my bible when I rebuilt the car years ago. I still refer to it when doing some major repairs, like the kingpins. The previously mentioned Practial Classics book mentioned is similar, though between the two I'll go for the Lindsay Porter book.
Colin
T Best Shop Manual for BE Spridgets 9
B MGB-GT Best rust repair person/shop on the East Coast? MG 2
B Best shop floor surface? Triumph 21
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
