TR4/4A Best head gasket for a 4A?
tdskip
Hi guys, hope everyone is having a good start of their week.
Is there a consensus on the best quality / durable / least likely to have to do it again head gasket for the 4 cylinder engines?
Thanks in advance for the tips.
DornTRoriginal
My humble and somewhat inexperienced opinion, I am a TR3 guy but it is basically the same engine, there are a few options available to you, what you decide to install depends on a few factors such as engine configuration, driving habits and personal preference. I found there were four options; copper wrapped composite, a composite gasket and a solid copper or shim steel used on competition engines which are provided in various bore sizes and thickness. The solid copper, like the steel shim gasket, seems to be used mostly, if not exclusively, by racers with high compression engines and the other more widely used copper and composite are available from the usual suppliers are quite common. I think the composite HG available from Moss is a high quality HG and would be quite durable for most uses and does not require gasket sealant I am told. The copper wrapped composite and solid copper do require sealant and are also good well tested and used options. I think it is important to have a good flat head, good head studs (I replaced mine with the ARP High performance studs) proper piston liner height alignment etc. and to correctly install the HG. If you have a quality installation no matter which option you choose, you should be good to go for a long time!
TR3driver
Great Pumpkin - R.I.P
Cometic is the name I keep hearing, for best quality original type head gasket. Payen was good, but my understanding is that they no longer make them.
groupdeville
I'm curious about the Cometic gaskets as well - they're sold for Miatas as well as LBCs, and at least one well-respected Miata place (Flyin Miata) seems to believe in their use.
Geo Hahn
So is there a Cometic head gasket for the TR3/4s?
I have used Cometic in several applications on my other British car and they have done well. I particular their composite gaskets are a big improvement over some originals that used paper (water pump, cam covers, etc).
mallard
It took me three tries to get the gasket to seal on my TR3. first try was with a Payen gasket then a Lucas gasket without the sealing rings because they were not available at the time. All three gaskets were purchased from BPNW or should I say the first one was because they replaced the first two that leaked N/C. First class people at BPNW. The part number for the gasket that did not leak was AE330HDL at $67.00. You can look up the description as it is unlike all the others available. I've only put 1000 miles on the car but so far it's been fine. When I rebuilt the engine I think I should have had the top of the engine block shaved because it did have a few scratches from being in storage. At the time I did not know about the guy who sells different thickness figure-8 gaskets.
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
TulsaFred Best head gasket? Spridgets 9
mjobrien Head Gasket - Best Practices Austin Healey 8
1 Best way to remove this snapped head exhaust stud? MG 13
G Spitfire Best Euro 1500 Spit head? Triumph 0
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
