Bellhousing Blues
Guy Marshall
Hi all,
Reinstalling a rebuilt BN6 side change gearbox I discovered the PO had replaced the slave cylindar mounting bolts with 20mm M10 metric bolts which have now stripped out.
There seems to be plenty of space to re-tap with longer (1½"?) 3/8" unf bolts but has anyone had any experience/recommendations?
steveg
20mm seems short (roughly 3/4"). Maybe there are still good threads in the hole. You can make a chasing tap out of a 3/8-24 bolt. This one's 1-1/4" long:
Otherwise you might be able to loctite studs in the holes, or install helicoils.
G
Guy Marshall
Score 1 for the good guys!
A thread clean, then two longer 1[SUP]3/8[/SUP]" screws to replace the metric ones that had been forced in and a little loctite and the slave cylinder is working.
I'll get some helicoils too...
Thanks all!
Do it once. Do it right.
Every Healey I get the opportunity to, I put Heli-Coil/Re-Coil inserts into the slave mounting holes. I once had the slave cylinder fall completely off my car in Lafayette, Louisiana (a LOT easier to deal with than the time I had a clutch hose burst on an MGB in San Francisco).
Patrick67BJ8
My bellhousing for my Toyota trans only has one bolt to attach the slave cylinder to it. There’s a stud for the other mounting point. Simplies removal and replacement.
steveg
Interesting there are multiple cases of stripping these holes in aluminum. Guess there are few aluminum bolt threads on a Healey. The only other ones I can think of offhand are on the steering idler.
Are folks using "cast iron" torque on these aluminum threads and stripping them out? Or are the slave cyl bolts at such an awkward angle as to promote cross-threading?
Enquiring minds...
Dandare
I think that a fine thread into aluminium was kind of frowned upon in engineering circles and even BMC/BL changed to UNC later.
Could it be worsened with the ageing of the ali.
Danny
steveg
Danny
Interesting. Sounds logical. I believe the Smitty bellhousing uses coarse threads for the slave attachment.
Addendum: So the optimum setup would be to tap the holes for a coarse helicoil.
Dandare
Nothing wrong with the insert being fine and you can still use your original bolts if they're good.
Danny
Keoke
Enquiring minds...
Must be I never had any problem like these. //
Maybe dissimilar metals corrosion contributes? IIRC, mine stripped really easily, and I'm not THAT ham-fisted. That, or trying to get the slave off and on in situ, with all the hassle that entails. I never use split lockwashers on aluminum, BTW; the washers dig into the soft metal and release tension on the bolts. I use Grade 8 flatwashers under the bolts, with blue threadlocker.
G
Guy Marshall
@steveg - mine had a pair of bastard 25mm M10 metric thread bolts forced in which is why they stripped. Happily the M10s were very short so I could clean up and extend the thread and replace with 1 3/4 3/8 UNF bolts which is now "better than new". For what thats worth!
WHT Center-Shift Bellhousing Austin Healey 10
Jake Help ID gearbox/bellhousing? Jaguar 12
Y MGB A bellhousing mystery.... MG 3
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
trotti Bellhousing AEC 32933 - which engine? Austin Healey 4
K TR2/3/3A Gearbox bellhousing to motor bolt size? Triumph 12
BoyRacer BN2 bellhousing - how rare - price? Austin Healey 2
S Spitfire Triumph Spitfire 74 transmission bellhousing leak Triumph 6
J Bugeye exhaust/bellhousing bracket Spridgets 1
I Correct bugeye bellhousing exhaust bracket? Spridgets 8
J Spitfire Spit 1500 Bellhousing Problem Triumph 0
eschneider MGB mgb trans oil drip into bellhousing MG 8
TimK Dowel bolts for Transmission Bellhousing Austin Healey 2
B Buffer Pad in Bellhousing. Austin Healey 14
JoeC TR6 TR6 Bellhousing assembly Triumph 9
Tullamore Lost Washer in Bellhousing Spridgets 6
T TR2/3/3A Hole in transmission bellhousing TR3!!!! Triumph 5
bighly Buffer on bellhousing Austin Healey 2
E V12 bellhousing Dimensions? Jaguar 6
R Steering wheel blues Spridgets 7
stretchit2 Oh No I Didn't or the Dropped Not Blues Austin Healey 6
jmwuva05 H1 blues Spridgets 5
B Hardtop blues Restoration & Tools 2
bigjones Tow truck blues - good analysis for you to ponder Spridgets 33
PatGalvin Wheel bearing grease seal blues - they continue Triumph 15
Tabcon New Starter Blues Triumph 2
bugimike The new hood blues! Spridgets 15
G "Stormy Monday Blues".... Triumph 7
MGBGT_noob The DPO blues MG 16
2wrench Got the Bently Beckoning Blues Triumph 22
L Overdrive Blues Triumph 19
G Starter Blues Triumph 18
Andy Blackley Wheel bearing blues Triumph 5
kcbugeye1275 Salvage yard Blues Spridgets 0
R6MGS Cadillac Blues.... Other Cars 10
P Freeze Plug Blues Austin Healey 12
mcguijo TR2/3/3A TR3 Transmission Blues Triumph 16
Morris Old Head Gasket Blues MG 9
E Ignition Blues MG 13
mylillooker I got the Eletric Blues Spridgets 9
