Ballast resistor
airlifter
Does my car have one and if so where is it located? It is a 69 TR6. I was adjusting the carbs this afternoon and the car had been running for a while at idle. It quit once and I suspected a fuel problem so I checked to make sure fuel was getting to the carbs. The coil must have cooled down while I was doing this because the car started.
In a few minutes the car quit again. I checked for spark from the coil and there was none. The coil was so hot that there was fluid coming out of the top.
The wiring diagram does not show a ballast resistor. The dist. Is a new rebuild from Jeff. The positive post on the coil is connected to 12v and the negative side to the points.
The coil is an Accel Super Stock from Universal Performance.
I read 4.7 ohms across the low voltage terminals. The car had a Petronix electronic ignition when I bought it but I changed it back to points.
Just a bad coil or other problems (I mean challanges)?
poolboy
Not until 1973 did the engines have a ballasted ignition.
It was just an additional wire attached to the positive terminal of the coil. The length and composition of that wire created higher resistance.
A
airlifter
Any idea what would cause the coil to get so hot?
TR3driver
Great Pumpkin - R.I.P
There are several different models of Accel Super Stock coil; but AFAIK all of the "points" models require an external ballast. You'll need to either add a ballast resistor, or get a coil that does not need one.
Using a "ballast required" coil without a ballast means the coil is seeing twice as much voltage as it expects, which means twice as much current as well, for four times the power dissipation. That's why it gets hot. The heat will shorten the life of the coil and I've even seen it melt the points!
Your FLAPS should have a generic ballast resistor available. If you have to give them "make, model & year", tell them it's for a 1963 Plymouth Valiant.
https://www.rockauto.com/catalog/moreinfo.php?pk=933069
Seems like there is likely something wrong with your ohmmeter as well. Should be around 1.4 ohms for the "points" version, or 0.7 for the "electronic" version.
A
airlifter
The coil is the 8140 model. I will get a new coil tomorrow. Is there and advantage using the ballast resistor? I would rather stay with the non-ballast type.
I am considering going back to the Petronix ignition. Can I use the same coil for the points and Petronix?
poolboy
I know you can use the DLB 105 with the Pertronix and of course the 3.0 ohm Pertronix Flame thrower. Thats' the combination I'm using now.
Without getting too technical, the advantage to a ballasted igntion is that for faster engine starting, the coil is supercharged by feeding it 12 volts while the starter is being used..kinda like what you've been doing full time.
Then once the engine starts and the starter is disengaged, the ballasted wire feeds the appropriate lower voltage for that particular coil to produce spark.
You can google ballasted ignitions if you want and get into primary and secondary windings and all that stuff
TR3driver
Yes, in fact Pertronix warns to only use a "point type" coil. But if it is a ballast-required coil, then it still needs a ballast, with or without the Pertronix.
As poolboy notes, the ballast gets shorted out during starting. But the battery voltage is not 12v at that point, and may be as low as 6 or 7 volts on a really cold morning with a somewhat tired battery. The main advantage is easier starting in cold weather, for engines with a lot of smog equipment (that tends to make them hard to start). In general, unless you drive in weather well below freezing, I doubt you'll notice the difference.
Jim_Stevens TR2/3/3A Ballast resistor to prevent hyperflashing Triumph 5
NutmegCT ballast resistor Other Cars 10
TulsaFred Ballast resistor Spridgets 28
regularman Ballast resistor mystery Spridgets 2
A ballast resistor 75 mgb FORUM Navigation Questions 0
A MGB ballast resistor 75 mgb MG 2
H Ballast resistor MG 9
RynoBoy74tr6 Ballast resistor location.... Triumph 10
newmexTR3 TR2/3/3A Pertronix on TR3 Ballast Resistor or no? Triumph 3
8 BALLAST RESISTOR???? Triumph 12
J Spitfire Spitfire Ballast Resistor Triumph 3
C Ballast Resistor Spridgets 34
B TR6 TR6 / Pertronix / Ballast Resistor / etc Triumph 13
RichC Primary Ballast Resistor Ignition? MG 1
R Link to Ballast resistor wireing Jaguar 0
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Marla TR4/4A Ballast or Non... Triumph 6
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
SilentUnicorn MGB ballast wire mgb 77 MG 2
T External ballast resistors - do they go bad? Triumph 8
john_j Coils and ballast resistors Rover / Land Rover 2
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
19_again resistor MG 2
J Tach resistor Spridgets 8
H TR6 tr6 heater motor resistor Triumph 0
