andrewengelman
I have a 1975 MGB and I wonder if it has a so called ballast resistor. I can turn on the key, the engine starts and when I remove my hand from the key it stops. It appears that the ignition switch is fine because on other occasions when the engine is cooler it will start normally. Any advice would be appreciated.
