Okay, you've gotten some pretty good suggestions from some of the others. I'm gonna throw my two cents in.
When you rocked the wheel did you have someone look behind the wheel to see where the play was? Sometimes trunnions will wear, but yours looks in very reasonable shape. Your pictures of the bushings show them to be in good condition. So, I wouldn't worry about replacing them for awhile.
When you put the wheel back on does it rock side to side?, indicative of tie rod end freeplay. could be outer or inner. The inner is under the boot on the steering rack. Mostly the outers wear long before the inners.
I didn't see a greasecap for the wheel bearing in your picture. That is an important protective device to acquire.
AGAIN and AGAIN When you take the hub off(unbolt the two bolts mounting the caliper to the front spindle assy., pry the caliper up and hang it with a large tierap or something to keep from stressing the brake hose, remove the cotter pin, unscrew the nut and rock the hub, the outer wheel bearing will come off in your hand and then you can pull the hub off of the spindle.)
The old seal, if it's felt, will have the inner part stuck on the hub. wipe the spindle down to make sure there are no gouges, or ridged depressions worn in it.
Take the old bearings and seal to a bearing supply house and get replacement bearings. I cannot stress this enough!
Get modern bearings! They are made to closer tolerances, they have more rollers(If I remember the outer race only has somethin like 4 or 5) So the load is spread out. You can always take the hub down to your friendly Western Auto and they can replace the bearing inner races if you feel insecure about that part. Have them pack the bearings so that when you put it back together you have plenty of grease on the bearings and about two tablespoons of grease in the space in the hub between the bearings. The updated seal will be either National or Chicago Rawhide(rubber) and will tap into the back of the hub. When you install the hub back on the spindle, tighten the nut up as you turn the hub slowly, to seat the bearings. You will tighten the hub up until it almost stops or completely stops(depending on how the fit on the spindle is) Then back it off to the first notch to fit a new cotter pin in.
Put the grease bearing cap on(with a little grease in it) and the caliper back on, after the caliper on pump the brake pedal a couple of times. Bolt the wheel on and drive it.
If you haven't visited them you might try going to the "How Stuff Works" website, automotive and search for front wheel bearings. It might be helpful.
Later as your confidence grows(or folks come visit you during the summer) you can venture into bushing/shock replacement. But the pictures you posted show that is NOT necessary at this time.
Have fun in Aruba!
