Anyone install one of these [100S Kilmartin pieces] for fresh air in your footbox?
55modified
Looking through Kilmartin 100S parts and came across this. Never seen this in any photos or books on an original. I like it and bet it would help. Anyone installed these on top of their foot box? Screenshot_20170930-220200.jpg
roscoe
images.jpgNot me but how could it possibly be a bad idea? Anything that helps move air near my feet on a hot day would be welcome. I have glorious plans for installing a mini swamp cooler along the lines of the old ones you could hang on your window.......dang, I don't have a window.
55modified
55modified
I cannot get any response from Kilmartin by emailing them. I am using their email from the website. Has anyone ordered from them recently?
I haven't dealt with Kilmartin in a long time, but recall it was easier to reach them by phone (but the time difference is a hindrance).
RAC68
Hi All,
I believe the Kilmartin part is an extension/modification on the COLD Air outlet that will angle the air stream downward into the foot well. The original Cold Air outlet directs air high and to the back of the dash and thereby eliminating most of the cooling benefit for the driver. This addition/modification changes the direction of the "Cold" air output to better address the heat issue of the foot well.
Keep in mind that the 100/S was RHD and I would expect this piece to direct more of the cold air toward the foot well across the cabin.
Although the Kilmartin part could provide beneficial Cold air redirection on a 3000, a simple deflector mounted on the bottom of the wiper motor mount (attached with the wiper motor bolts) would perform as well and require much less intervention, effort and cost.
My Guess,
Ray(64BJ8P1)
55modified
55modified
IMG_4411.jpgAH914S.JPGOrdered one along with the air deflectors for the front. Will post up some photos once installed.
RAC68
I'm a little confused, are the air deflector parts (pictured) installed inside the cabin or in front/on the radiator bulkhead on the cold air duct?
Ray(64BJ8P1)
55modified
55modified
The air deflectors are installed on either side of the radiator behind the grill to channel the air through and not allow it to escape around the side of the radiator. The smailler piece sits on top of the foot box and appears that it could go on either side on the outside of the diagonal supprt to the firewall. Below is a photo of what the air deflectors look like installed.
RAC68
Would the hole in the deflectors be the opening for extensions of the cold and heater air ducts? The deflectors seem like a more inclusive channeling of air to the radiator then the deflectors on the BJ8/3000 and would even diminish some of the hot air recirculation during a slow moving or stopped situation.
I look forward to hearing your experiences when installed.
Ray(64BJ8P1)
55modified
55modified
Yes the hoses will run to the cabin inside each respective fender. Stock appearance for passenger side and the driver's side should fit similar (I am hoping). I don't see any downside except I don't have a control flap to shut off the air on the driver's side like factory passenger side.
MikeAH100M
For 100M/Lemans owners, this might be an interesting way to not only mount the hose to the cold air box but to install a filter. I've tired several ways to install an air filter and this seems like it would be sturdier.
RAC68
If the closing flap for the 100 Cold vent is installed as it is on the BJ8, in the radiator bulkhead, then I would expect you would leave all in place and just run a duct from the forward side of the bulkhead Cold air duct to the opening in the deflector. This may require the construction of a bracket on the bulkhead to hold the additional duct but it would leave everything as in from the radiator bulkhead back to the cabin ... no change. A water exit/drain (in case of rain) should also be considered at the forward duct mounting bracket.
Ray(64BJ8P1)
55modified
55modified
Not familiar with the flap on the BJ8 will have to investigate that. Thanks again.
frankenstang57 top install tips anyone? Triumph 4
T Wedge Anyone install these TR8/Rover bushings? Triumph 11
T Anyone install a horn button? Triumph 1
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
