Morris
Okay, I lied. This is just a continuation of my old cam post, but I felt like I needed to "doll things up" a bit to get some attention. What can I say I am impatient.
So here's where I am with timing my cam. I have used a dial indicator to find TDC. My dial indicator is now following the intake lifter for #1 cylinder. I have a degree wheel on my crank. What I am having a hard time understanding is how to read my degree wheel to determine if my cam is aligned properly.
Here are the numbers I have for my stock 1500 cam.
Here are all the numbers I have:
Lobe centers 112°
Intake timeing 18°-58°
Seat duration 247°
.05" duration 205°
How do I translate my degree wheel readings so that they relate to these numbers. It seems that these values have many common names and I think that is what is confusing me.
Lemme throw this out: Starting from TDC before the intake stroke, I take a degree wheel reading when my tappet reaches .05" lift; I take another reading when it returns to .05" lift. I add these two readings, and if everything is aligned correctly, the sum should be 205°. Is that right.
If I use Hap's technique of finding the upper most part of the valve opening (see my previous thread), the result I should get will be 112°. Is that right?
I am so confused.
Lobe centers 112°
Seat duration 247°
.05" duration 205°
I am so confused.
