TR2/3/3A 3rd. brake light set up
One possibility is to replace the license plate lamp with the combo lamp from an earlier TR3.
Another is to add some relays and make the turn lamps come on with the brake lights (but still flash if both brake and turn signals are on). You can buy logic devices that will do it with a single box (eg https://www.amazon.com/IIT-16690-Trailer-Converter/dp/B004EKW0DC) or build it yourself with 2 or 3 cheap automotive relays. However, either approach will require that you either change the turn flasher or add some power resistors to make the original flasher work right.
Under the heading 'crude but effective' I use half of a set of Harbor Freight towing lights (with a magnetic base) to have a 3rd brake light when I know I will be driving in city traffic:
I added a flannel pad to go between the base and the car body to avoid scratching - also important that the pad is clean and the body is clean and waxed.
Wires just sneak into the boot over the seal and connect with bullet connectors.
The Hoppy converter is available on the internet or at your FLAPS. Part number is 38845
It is recommended that you convert your rear turn signal lights to LEDs.
The HOPPY converter cannot handle much more than
2.1 amps total.
LATE 3, 3A, 3B CONVERSION
>>>>>>>>>>>>>>>>>>NEGATIVE GROUND SYSTEM ONLY<<<<<<<<<<<<<<<<<<
TRIUMPH COLOUR CODES
Black (57) = ground Red (44) = Tail lights Green w/red (18) = Left turn
Green w/purple (22)=brakes Green w/white (21)= Right turn
This converter integrates the brake lights with the turn signal lights, allowing the turn signals to function as brake lights as well. When the brakes are applied, all four lights on the rear apron are illuminated. If the turn signal is applied while the brake is applied, that filament will blink. The advantage is that you now have 4 brake lights instead of two.
Installation instructions:
Locate the loom in the trunk (boot) area. It normally comes down the right side of the body along the fender well base. Choose a spot just before the wires separate out of the loom for the right tail light. Peel back the wrapping, exposing the individual wires. If the colours are still visible, identify each wire either by number or function. Disconnect the battery.
Cut all four wires, then strip ¼” off each end. The exposed ends should be bright copper. Should the bare ends have a dark residue on them (50 years old!) scrape them with a knife edge to assure a good electrical connection. Crimp type connectors are OK, but soldering is suggested. If soldering, use shrink tubing to isolate the solder joints. Be sure to insert the tubing before soldering!! The converter needs to be grounded. Drill a hole in the fender well and attach the ground wire(s) using a sheet metal screw. Note: The inbound side of the converter has a brake wire but the outbound side does not. Once all the connections are completed, reconnect the battery and the conversion is complete.
2.1 amps total.
That number appears to be obsolete, not listed on the Hopkins web site. But the 48845 appears to be similar. Website says the 2.1 amps limit is per stop outlet, which makes a little more sense.
https://www.hopkinstowingsolutions....light-converters/tail_light_converter_12.html
Curiously, the one I linked to doesn't mention a current limit (but no doubt it has one).
Also under the 'crude but effective' heading is using an LED assembly that fell out of a Celica spoiler. I mounted mine 'permanently' to the highest bar of the trunk rack with some plastic wire clamps. I drilled the lock to allow the wire to enter the trunk via the center of the lock (a small dab of silicon made it waterproof) and grounded to the lock (top and bottom of a mounting screw). I also added a very small in-line fuse from the regular brake light power to the 3rd light in the off chance something in the added circuit shorts out -only the 3rd light would be out and not the other brake lights.
The federal regulation for a 3rd brake light requires it to be higher than the other brake lights, and I think I am much more visible in traffic.
Moss Motors sells a slim, chrome plated, LED light...part number 116-115. I had it mounted in the small space between the gas filler cap and the top. Looks good and sits up high to be effective, and bright with the LED.
Hi,
I mounted a Optronic 1" x 1.5" x 18" LED strip to the tonneau cover, in between the Lift the Dots. In the winter I can mount it to the top. I have a quick disconnect for easy mounting. One nice feature about it being so high, I can see it in the rear mirror, so I know the brake lights are working.
RG
I made mine and had it chromed. It can be removed in 30 seconds if I'm at a serious event like VTR or TRA.
Any thoughts for a positive ground CHMSL? I do run positive ground LED brake lights...
Would love Don's solution if positive ground.
I've seen Don's first hand and it is great. I did start out trying to duplicate something similar but found it hard to get enough clearance from filler cap, without the light looking a bit too high. In the end, I placed my extra brake light at the bottom of the licence plate (sorry not great picture). Perhaps not an ideal location but the LED is much brighter than the single centre brake light I have, and it blends in pretty well. As well, I added a flash module to that light that flashes it fast three times before going on constantly while brake pedal is pressed. Note that such a light may not be legal in some (many) places. To me it ads a lot of extra visibility and is no different than pumping the brakes at bit. The wiring is run down from the boot into the spare tire cubby and I have a simple 2-prong trailer connector there to disconnect the wires should I need to remove spare or access anything else in there. I definitely feel a bit safer now in traffic.
Cheers, Mike
The one that RG linked to above can be wired either way. https://www.etrailer.com/static/images/pics/s/t/stl79rb_10_250.jpg Just ground the red wire (black too if you want) and link the white wire to your brake light switch.
Others I've seen can be easily modified. Just find the ground strap (usually a strip of metal running over to a mounting hole) and cut it, then solder a wire to the cut end from the lamp.
RAC68 Third *[3rd] Brake Light Austin Healey 11
K TR2/3/3A 3rd brake light question Triumph 3
T 3rd brake light again! Austin Healey 29
T 3rd brake light or LED's Austin Healey 28
K Up-date on Blinking 3rd Brake Light Triumph 1
B Cheap 12 light LED 3rd brake light Triumph 3
H 3rd Brake Light Austin Healey 8
kcbugeye1275 3rd brake light Spridgets 12
Brosky 3rd Brake light - windscreen ideas for roll bar?? Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
Joe Reed MGB Dropping out of 3rd gear... MG 2
R TR6 Gearbox slips out of 3rd gear Triumph 14
Gray_Cat Socal Norton Owners Club Annual Meet, Ride & Show November 3rd, 2019 British Motorbikes 0
B TR4/4A 3rd/top gear syncro hub Triumph 2
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
1 MGB 1966 MGB hard shifting into 3rd MG 1
D license plate lights, trunk and 3rd stoplight out Jaguar 4
Johnny Bad 3rd member for an OD transmission. Austin Healey 0
A TR4/4A TR4 Slips out of 3rd gear Triumph 5
T Hail Mary on 3rd gear syncro Spridgets 3
8 Lost 3rd & 4th Gear ?? Triumph 18
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
Johnny 3rd and 4th gear baulk/rings Austin Healey 16
R gear shift stick movement in 3rd gear question Spridgets 46
Michael Oritt Lime Rock Park July 3rd Racing 4
G 3rd time is a charm Spridgets 0
J Downshifting from 3rd to 2nd Austin Healey 7
T I like 3rd gear!! Triumph 29
bcbennett Heater Assembly 3rd bolt Triumph 1
MadRiver No O/D in 3rd Austin Healey 6
tahoe healey in 4th and 3rd/OD Austin Healey 3
PAUL161 MGB-GT Britts at the Battleship, Wilmington, NC Nov.3rd MG 8
roofman 3rd brakelight installed whatcha think? Triumph 45
S 3rd gear grind Triumph 7
TR4 June 3rd British Car Show in Perrysburg, Ohio Triumph 5
ChrisS What not to do at 6800 RPM in 3rd gear... Spridgets 31
tony barnhill theAutoist 3rd Annual Christmas Sale Sunbeam (Rootes) 0
ChrisS 3rd Gear Assembly Spridgets 6
zimmy sticks in neutral?....3rd gear slip....... Spridgets 3
tony barnhill Banjo 3rd Member MG 5
W Well I still have 3rd & 4th gear anyway! Triumph 3
D Mainshaft 3rd gear end float MG 0
jerrybny RPMs in 3rd Triumph 1
tahoe healey 3rd gear screamming Austin Healey 9
M Brake Caliper Attachments Austin Healey 4
M Brake Servo Austin Healey 8
B MGA Axle Brake line MG 0
