3-Synchro Gearbox Part - "The Pill, 22G89"
dklawson
Later this fall I will rebuild the gearbox in my Mini. There are a few parts shared between the early Mini and Spridget gearboxes. I'm looking for information, observations, and measurements for "The Pill", BMC part number 22G89.
This is a hardened pin, radiused on both ends. It is 3/16" in diameter but I don't know the exact length (it is approximately 9/16" long). It is used on the 1st/2nd selector hub on 3-synchro gearboxes. It is supposed to somehow control/prevent overthrowing the shift which in turn prevents the selector hub from spewing out its detent balls and springs.
My questions are:
1) Does anyone have one of these 22G89 pins that they can measure with calipers? My practice/parts gearbox is missing this and a couple of other parts. I can make a practice pin out of an alloy dowel but I need the end-to-end length measurement.
2) Can anyone explain how this pin is supposed to work? I can see that it goes into a full radius groove on the gearbox mainshaft and that sliding motion of the synchro hub SHOULD allow the pin to lock the inner part of the hub to the mainshaft. I just don't understand what's supposed to happen and still have the outer ring of the hub able to move to engage gears.
Any observations and measurements will be greatly appreciated.
Gerard
Hi Doug,
Length is .560" and diameter is .186"
If you look carefully at the cogs on the inner side of the 1st gear ring, you'll find that only one has a ramp to one end of the ring. This ramp must be aligned with the position of the hole in the inner hub where the "pill" is inserted. Getting the inner and outer hubs oriented to each other in any other way will prevent you from selecting 2nd gear.
dklawson
dklawson
Thanks Gerard. I used a 3/16" alloy dowel pin and made a pin that length. I carefully installed the inner hub in the outer ring so the ramp would engage the pin.
After fitting the hub assembly to the mainshaft I am still unclear the purpose of the pin. I know it is necessary for shifting but I didn't see what it actually does. Can you shed any light on the function of the pin? How does engaging the ramp with the pin alter the action of the 1-2 hub?
Thanks for any general information you can offer.
J TR2/3/3A TR3A 3-Synchro Gearbox Rebuild Triumph 26
5 3 rail, 4 synchro gearbox assembly question Triumph 9
Jayrz 3 Synchro Gearbox Wanted MG 19
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
R TR2/3/3A Transmission synchro detent balls and springs Triumph 10
J Synchro ring inspection. Austin Healey 5
19_again brass or steel synchro rings MG 7
Jayrz Rebuild a 3 Synchro Trans MG 5
71tr Synchro Cups Triumph 1
Bruce Bowker MGB MGB synchro 1st gear MG 5
jaybird 3 synchro od...when do I stop? MG 16
A TR4/4A TR4 Tranny -did it come non synchro?? Triumph 15
J Transmission... Replace synchro, or whole new tranny MG 6
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
