1998 Chevy Cavalier [yeah I know]
T
TRDejaVu
It's my Son's and I have 2 weeks to fix his rear defroster before he goes back to college and winter in NW PA.
It is getting 1.54V at the heater grid. I tried different ground paths, but always 1.54V. I tried to get to the dashboard switch to check the voltage there, but unless I take the top crash pad off (and passenger airbag), then I can't get to the bolts that let me remove the front trim panel.
Any ideas from the GM-ites on what this might be?
Mickey Richaud
Any way to check voltage at the grid itself? My first thought would be broken grid wire...
Can you disconnect the grid from the power source and check continuity of the grid?
T
TRDejaVu
Thanks Mickey. 1.54V coming from the grid power wire and also at any point across the grid. I'm thinking that there should be 12V coming into the grid.
Mickey Richaud
Yeah, you'd think it should be 12 volts. But if there's a compromised wire in the grid, I'm wondering if the circuit itself would be compromised.
Grabbin' at straws here...
Banjo
The feed wire should be full voltage, and touching a test probe across the grid wires should give a progressivly lower reading until you have 0 volts on the ground side.
Having a broken wire in the grid just renders that wire inoperative. The rest should work fine.
Possibly a poor contact in the switch, or a bad connection somewhere upstream.
If you can, test the voltage where it comes out of the switch. That will tell you if the bad spot is before or after there.
With the tester, keep breaking the circuit into smaller and smaller parts till you find out where the issue is.
Best of luck.
T
TRDejaVu
I had tried getting to the back of the switch, but they built the whole car around it!!! I checked that I had 12V at the fuse; don't know why it wouldn't, but at least I knew. So that left me stumped and in "dang it" mode. I then flicked (can't describe it any other way) at the switch and after 6 months of it not working, the light came on and full power appeared at the grid. I suspect that the switch is on the way out, but for now it works. I have shown him the "flick" should it fail again, so we'll see if we can get another winter out of it.
Thanks for the responses.
mailbox
By what you have described you are getting a feedback of 1 1/2 volts thru the ground side. I think you are right about the switch.
tony barnhill 1998 XK8 Jaguar 15
BritCarFan 1998-2002 Land Rover Discovery Rover / Land Rover 1
tony barnhill 1998 Triumph Thunderbird Sport British Motorbikes 3
Keoke 1998 -t0-2001 BMW M6 roadster Other Cars 15
B 1998 XJ8 Wiper over-run Jaguar 0
B Buying my 1st jaguar [1998 XJR] what should i do first? Jaguar 6
Basil Ultra rare 47 Chevy Spotted 7
TomMull Inspection/maintenance (I/M) readiness 2005 Chevy Astro Other Cars 1
AngliaGT Chevy Chevette Spotted 12
AngliaGT Chevy Van Spotted 5
GTP1960 Spotted this old Chevy fire truck in Porto Portugal Other Cars 3
aeronca65t early 50s Chevy Other Cars 1
AN5Sprite Porsche 356 w/ bonus Chevy Spotted 4
JPSmit Chevy Truck - and Lada Niva Spotted 0
aeronca65t Tesla + Chevy truck Spotted 0
PAUL161 Chevy P 30 chassis brake hydro booster? Other Cars 0
BobMunch Video of 1936 Chevy assembly line film Other Cars 1
A T-Series mg tc-chevy s-10 MG 6
PAUL161 The Chevy 789! Wow! Other Cars 5
P 1953 Chevy 1 Ton Wheel Options Other Cars 6
jackq Chevy truck Other Cars 7
14dna Chevy S10 Other Cars 14
Adam58 MGB-GT MGB GT vs. Chevy Avalanch MG 27
H Insurance on Chevy Truck Other Cars 8
tony barnhill 1962 Chevy Nova II Other Cars 6
beaulieu XK 120 with Chevy V-8 ? Jaguar 12
Bruce Bowker Chevy in flood Other Cars 11
Moose33 1954 Chevy Other Cars 2
Carlover325 Chevy Astro Other Cars 11
W John's Cars, Inc. Chevy V-8 Conversion? Jaguar 29
