MGA 1960 MGA Rear Brake Cylinder
DaveR
Restoring my MGA's complete brake system.....got to the rear cylinders (drum Brakes).....any ideas on disassembling frozen
rear brake cylinders...without destruction?
LarryK
Soak them with a good penetrating fluid, then apply air at the bleeder hole. Be careful as when it lets loose it will fly hard and far. Rags are best bet to surround it as you apply air. Might take a while to soak it free.
bob67bgt
you will need to get the tin metal cap(attached to upper piston) off the cylinder to remove the pin that holds the e brake lever in before it will come apart. If it does not come apart reasonably easy then replacce the cylinder. Brakes are way too important to take any chances with. That tin cap will break off the upper piston pretty easy. Soak and you may get lucky. Bob
K MGA 1960 MGA Vin MG 3
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
apbos MGA 1960 MGA 1600 our first MG! MG 20
apbos MGA $1500 1960 MGA in Woodland Ca MG 0
R MGA Over length of a 1960 MGA MG 2
D MGA 1960 MGA wheel problems MG 13
Sergio MGA 1960 WITH A BIG HEART XJS V12 Jaguar 10
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Pool Dad 1960 TR3 engine serial number Triumph 14
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
G 1960 3000 BN7 Top Help Austin Healey 0
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
J 1960 Bugeye Paint Codes Austin Healey 1
F 1960 FriskySport Barn Find Other British Cars 6
5 Proud of my 1960 Bugeye Spridgets 5
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
P 1960 Lancia Appia coupe Other Cars 1
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Nugget 1960 Bugeye "Patents" inherited reconstitution Spridgets 12
6 For Sale 1960 Bugeye Survivor for Sale with Original Rubber Mats Spridgets Classified 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
D Great Gas Mileage in Southern California [Circa 1960!] Austin Healey 3
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
red57 1960 BT7 top mounting brackets Austin Healey 4
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
T needed 1960 bugeye parts Spridgets 4
Tinkerman TR2/3/3A 1960 3A post 60,000 top installation Triumph 6
