1950 Prefect E93A-946480 - door bottom rubber
algot1901
Bronze
1950 Prefect
Need a photo of how the door bottom rubber is installed
Bayless
I will need that eventually too. I remember my first source years ago told me they just don't work. Just maybe a couple of years ago, I got a set from Small Ford but can't see any way to attach them.
algot1901
algot1901
Bronze
I will send you a pic later today
algot1901
algot1901
Bronze
This pic shows the frame and the location of holes drilled at the factory on the underside of gasket is a lip that goes against the frame.
Bayless
Thanks for the pic Jim. So do I understand right the rubber is attached to the frame instead of the door? Is it glued to the frame or what holds it.
algot1901
algot1901
Bronze
If you look at the frame the very top you will see a line of holes it is screwed on the under side of the gasket is a lip and that goes against the frame. the door goes against the gasket.
algot1901
algot1901
Bronze
Here you go hope you can figure it out I am a truck driver not an educator :smile:
Bayless
Wow! Educator or not, I think you have done a quite creditable job of educating there. I have the rubbers put away but even without seeing them directly, I think I understand now. Thanks again.
Bayless
Hey Jim, how are you progressing on your Prefect? How about some more photos?
algot1901
algot1901
Bronze
Hello,
All the painting is done, have to put the front fenders, hood, and grille on (found a really nice grille in England)old grille would have worked although I did not want to mess with it and found a nice hood latch.
All the glass is in just need to do some tweaking
Have to make a couple of new wooden bows then put the top canvas on and the headliner.
Have to cut new door panels and kick panels, I bought the boards at > Restricted Access <
My son James has to weld in the new rear shock mounts (tubular, have the fronts done).
The radiator needs to go in and we hope it will not leak, took it to a radiator shop to get the tanks re-soldered, and also the mice nesting burned that stuff out so we had to flush out the radiator. Bought a water pump 12V and holding off to see if it needs the pump. Also, bought a tiny alternator that will mount where the gen sat. Oh and the engine runs so that is where the Bean Fart is.
Jim
Bayless
Thanks for the update. "Engine runs" is good news. Keep us posted on your progress.
AngliaGT
Is Dean Kirstin still around? (Anglia Obsolete).
Bayless
Doug, I talked with him a year or so ago and his web site is still online as of just now.
AngliaGT
I met him years ago at the Palo Alto British car meet.
algot1901 1950 Prefect starter Other British Cars 1
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
algot1901 1950 Prefect Ign Switch Other British Cars 1
algot1901 1950 Prefect Speedo Cable Other British Cars 8
algot1901 1950 Prefect Starter Other British Cars 10
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
algot1901 1950 Prefect Headliner Other British Cars 17
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
A Body Paint Codes for 1950 Prefect E493A Other British Cars 1
A Rubber parts for 1950 Prefect E493A Other British Cars 6
A 1950 Ford Prefect Windows Other British Cars 4
A 1950 Prefect Vacuum Tank Other British Cars 22
A 1950 Ford Prefect Floor Covering Other British Cars 2
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
T For Sale Parting out a 1950 Austin A-90 Atlantic drophead Other British Classifieds 5
J Wanted 1950 Austin sheerline A125 need brakes Other British Classifieds 0
J 1950 Austin a 125 Shoreline need parts FORUM Navigation Questions 2
D 1950 Jaguar Mark V Sunroof Question Jaguar 0
K 1950 Standard Vanguard Other British Cars 2
AUSMHLY 1950 Healey Siverstone Austin Healey 8
B 1950 Rover 75 P4 Cyclops value? Rover / Land Rover 9
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
G Brake fluid recomendations - 1950's JAG XK140 Jaguar 19
Z Austin A70 Hampshire [1950] as a donor car Austin Healey 1
kennypinkerton British Specials... from the 1950's Other British Cars 38
kennypinkerton More specials... 1950's Racing 1
Tullamore 1950 Simca Pinninfarina Sport Huit Other Cars 1
T looking for any info on a 1950 austin A40?? Other British Cars 5
Sherlock TR2/3/3A 1950's Triumph TR2 Francorchamps coupe Triumph 3
KLUTZ 1950 FORD ANGLIA. in Old Car Trader. Other British Cars 13
Kira Smiths Clocks Pre 1950 Other British Cars 6
B 1950 Healey Silverstone D-Type on E-bay Austin Healey 1
bighly 1950 MG YA [For Sale] MG 2
Bayless The Prefect Grille Other British Cars 0
Bayless More Prefect Progress Other British Cars 2
algot1901 50 Prefect wood roof support / bow Other British Cars 8
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 Brakes for Anglia / Prefect Other British Cars 2
Bayless My Prefect update Other British Cars 5
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
algot1901 Carburator 50 Prefect 1172cc engine 10hp Other British Cars 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Bayless Even more progress - the Prefect Other British Cars 5
L !953 Ford 4 door Prefect Other British Cars 3
KLUTZ Wow.. A Perfect Prefect ....... Other British Cars 2
A 1949 - 1952 Ford Prefect Other British Cars 9
