1500 - water pump - and hack saw
bigjones
Bronze
Remember, one supplier sent me the wrong plug wires? Well, a different supplier has sent me the correct head gasket - but to someone else!
So, still waiting on putting the CH back on..
Anyhoo's, I was pondering. It's difficult to install an electric fan behind the radiator because there is not much room between radiator and water pump. Above, is the original water pump - the extra length on the spindle is of course to accomodate the (now hated) fan clutch. Could a guy just hack saw off that extra length - blue arrow?
Looks like the original, Made in England, pump - it has been balanced, right? Red arrows.
Replacement pump has no such marks - is current technology such that they can now make pulleys perfectly balanced? Just wondering.
This waiting is killing me. I'm really worried about those head studs stripping out the block. I suppose it defeats the object if you oil them up prior to torquing down the nuts?
Cheers
Morris
I cut that shaft off on mine and still ended up mounting the fan in front of the radiator. I wanted to be able to get to the front of the engine without removing the radiator. Not sure what good that does me though....
Now I can't remember if the fan will mount behind once you remove that shaft.
Knock on wood... I have never had cooling problems with the fan in front.
The fan clutch I sent you should arrive today or tomorrow.
racingenglishcars
Why not oil the head bolts/studs?
It could be that ARP wants their bolts lubed, but the recommended torque on a bolt is based on a combination of bolt shaft stretch (which itself consists of shaft diameter and material), and friction of the threads. If using a non-ARP bolt and the friction is reduced, the bolt is tightened more than specified. It may be ok, but many times not. Obviously one could risk breaking something from over torqueing but also one must remember that the bolt doesn't just pull upwards on the threads, but the threads are cut at a 30 degree angle. This can therefore easier cause rounding of the tip of the threads... Who has ever done that?
jlaird
I bet it makes no difference at all weather you lub or don't lube. I dought that the spec is quite that close a tolarance.
G
On studs I don't believe it'll make a difference 'cause your not tightening that end. Lubing the nuts is a different story.
jlaird
Naa, I was thinking about the nut end Kelly. I bet it does not make a difference except for ease of turning the nuts unless they are really badly rusted.
We need someone to clean up a stud and a nut and test dry, then with oil and report on what they find.
bigjones
bigjones
Bronze
kellysguy said:
All torque figures I've seen state on a lightly oiled fastener.
Wow, that's sad.
I especially made a point of degreasing all the studs and nuts so that they were bone dry. Ha!
It has been my understanding (ie I read it on the internet, somewhere, sometime, by someone, I think) that they shouldn't be oiled because, like racingenglishcars says, you would be overtightening.
I have a feeling that the ARP stuff is an exception because ARP have specified a torque setting based on their tests and their tests were carried out with oiled studs.
Cheers
G
All my info comes from manuals and says to lighly oil. All this being said I nevr do. not 'cause I'm afraid of over tightening, but nuts comming loose.
THink about it, you lock tight to keep fasteners from comming loose, what would be the opposite????........oiling them, right?
Hehehehe, maybe I should lightly lube with locktight.
jlaird
Is this an Oximoran (sp)
I have always lubed every bolt/nut I have ever installed. No problems yet.
dklawson
Why not send a PM to Hap and ask him to offer his advice regarding oil/dry on head fasteners?
jlaird
I expect Hap to be along. How could he stay away from this. Hehe
racingenglishcars
Hey, I should probably clarify a couple small things. First If the manufacturer recommends lubing bolts, then do so. If they don't recommend lubing then don't. Second, lightly oiling is only to prevent rust, not for actual lubrication. That would imply oiling and wiping clean. Lubrication in this case would imply heavy oil, grease or copper grease/lube. Sorry for confusion.
I lube some internal engine high torque bolts, main bolts and studs, rod bolts, head studs (both ends) always have in those situaction, becaue dry threads are more lightly to cause and under torque than a over torque, I noramlly use 30 wt motor oil for this, if ARP, I use thier assembly lube. Other applications I use different things, on many low torque fastners in a engine I use locktite, on things that are likey to sieze from corrosion or heat I would use anti seize. Then some places I like to use different fastners than stock, for example on MG A and B series cylinder head, the factory was sleeping to use studs at the thermostat housing, I must have had to repair hundred heads here in my life for snapped studs there, I use bolts there, they will not snap. So there's my take on what I use on various fastners.
bigjones
bigjones
Bronze
Hap,
Thanks for that information.
What would you normally use on the head studs on a 1500 Midget and would you go back after a heat cycle and re-torque. If so, would you slightly loosen and re-torque each nut in turn, in the proper sequence. There is some debate about this.
Cheers!
jlaird
I know, I know the answer and my name is not Hap. LOL 30 Wt motor oil and never loosen till you are ready to remove. I am sure and Hap is of course the last word here, but I have never seen a change in over 5 lbs of torque from the first tightening and the retightening, and then only on a couple of studs.
In other words for a street engine it is not an issue. For an all out race engine I would even have the torque wrench certified annually.
I would bet that the chance that your wrench is off 5 lbs is greater than the chance the stud nut is off.
You do know that new cars today never have there heads retorqued from the orginal assembly. Think about that. Maybe, just maybe if it is done right the first time it does not need done agan.
However, that all said, I check em twice just because I was taught to do it that way back in the 40s.
Now when Hap says I am all wet.............
bigjones said:
Hap,
Cheers!
I would atleast use motor oil on both ends of the studs and nuts, and there would be no need to re-oil them, as the retorque needs to be done after 1 or 2 heat cycles, so there would still be oil on the threads.
M 1500 Midget water pump weep hole Spridgets 2
bigjones 1500 - water pump kaput Spridgets 171
R 1500 water pump weep hole? Spridgets 3
G Midget 1500 Water Pump / Fan Clutch Question Spridgets 6
P 1500 Water Pump/Fan Clutch Spridgets 3
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
