1300 cam bearings in Midget 1500
aadc170
Anyone know if cam bearings from a Spitfire 1300 would fit the cam for my '79 Midget 1500 if I had the block machined to accept them? I seized the cam and I don't want to have to get a new engine block just to get back up and running.
dklawson
I don't have a direct and simple answer for you. However, you could go to an online source like Spitbits.com or Victoria British and compare the part numbers for cam bearings and/or cams for the 1300 and 1500 to see if they are the same.
Of course, you could also pose this question on the Triumph portion of this board.
aeronca65t
I am pretty sure the answer is yes. You *may* need a 1300 cam (the journals may be different)
I just asked this question on the Triumph board last week and got an affirmative answer from one member.
For a definitive answer call Ted Schumacher at 419/384-3022
He owns TSI Automotive and is a Triumph engine guru:
https://www.tsimportedautomotive.com/
I just mic'd a stock 1500 cam . i get 1.965-1.966
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Can’t get idle speed below 1300 RPM Austin Healey 28
T Spitfire Help, Lack power on spitfire 1300 engine Triumph 12
johhny_utah 1300 crank Triumph 2
G Triumph 1300 head needed Triumph 20
JPSmit 1300 vs 1500 Triumph 11
rikiwho123 i started my 1300 Triumph 0
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
rikiwho123 rebuilding my 1300 motor Triumph 2
rikiwho123 rebuilding my 1300 Triumph 2
waltesefalcon 1500 head on 1300 Triumph 6
rikiwho123 Spitfire harmonic balancer for a 1300 spitfire? Triumph 2
rikiwho123 Spitfire stuck head bolts 1300 spit. Triumph 7
dklawson Spitfire 1300 Spitfire Compression & Leak Down Results Triumph 15
A Spitfire Spitfire 1300 camshaft dimensions Triumph 7
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
