TR6 TR6 under dash pics? Anybody?
TR4nut
I'm looking at a TR6 which was completely torn down then put together a little less than 'stock'. Right now the under dash demister/vent hoses are hanging very low. Does anyone have a picture or two showing routing? I could use both sides, but right now the worst mess is on the drivers side.
Thanks
Randy
trglory
Randy;
If you need to get to the demisters, you will have to clear a lot of room to work. At the very minimum, you need to remove the speedo and tach and the glove box. The demister hoses come from the rear of the heater box and the eyeball and floor hoses attach to the outlets in the front. Look at the drawing on the Moss web site to get some idea of what you should expect to see behind the dash. Work carefully to make sure you don't disconnect any wires when you are shoving things around back there.
Joe
TR4nut
TR4nut
Thanks gents- Tim, definitely what I needed. I can see I'm missing a large clamp that holds the air hoses closer to the steering column.
Joe- not sure yet just how much I will need to take out - the defroster setup is hopefully ok, my main complaint is the lower hose on the drivers side just hanging close to my legs.
trglory
Also check to see if the PO got a case of the lazies and ran full hose pieces (18") rather than cutting them to the proper length.
Joe
BobbyD
trglory
Dang, Bob! Everything is so neat and orderly! Here is the same view from under "the pigpen".
Joe :highly_amused:
TR4nut
TR4nut
Neat or messy, those are both very useful - thanks!
Bob- thanks also for maintaining that website of yours - great stuff there.
Randy
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
cmacmillan TR6 TR6 grille - rectangular tabs under the grille finisher? Triumph 2
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
martin_burtt TR6 TR6 - runs but no power under load? Triumph 11
TR6oldtimer TR6 TR6 rear body shims [under trunk] what is ok? Triumph 2
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
