why would an intake manifold stud have both coarse and fine threads?
twas_brillig
Okay: I'm trying to convert a 1972 BMW 2002 from carbs to EFI, using gutted Weber DCOEs as throttle bodies and a dual side draft intake manifold out of the USofA.
The car is metric; the carbs are metric; the studs connecting the Webers to the manifold are coarse 5/16" x 18 TPI and their other half connecting to the carbs are fine thread 5/16" x24 TPI.
I'm assuming that using the coarse threads into the manifold maybe are for manufacturing ease (but would appreciate comments from someone more knowledgeable than I), but why in heck switch over to fine threads for the nuts holding the webers to the manifold? Fine threads are stronger, but why switch? Any wise persons out there?
I guess I can just be thankful that they aren't British Standard Whitworth combined with goodness knows what.
Thanks,
Doug
Rhodyspit75
Coarse threads are used in softer metals such as aluminum. They won’t strip like fine threads will.
JPSmit
other than the course/fine - in terms of Metric/Imperial - would someone have replaced the stud with the wrong one?
Roger
Bronze
I have seen that many times, with metric, American and British threads. You use a coarse thread into the block, manifold, or whatever, particularly if aluminium. Fine thread is used for the attachment of the piece, where final tightening is done.
Just bot led the exhaust manifold (header) to a Lotus twin Cam head, same arrangement. Good practice!
T
twas_brillig
Thanks guys! The "coarse thread into soft metal" makes a heck of a lot of sense; I'm not sure why switch to the fine thread for the nut to bolt the carb to the manifold though.
We'll have to work up something as I'm adding about a 1/2" spacer to the existing 1/2" spacer so the studs won't reach. We'll either use coarse threaded rod throughout or maybe see if a bolt can be used (coarse again) to get a stronger end on the carb side. I recognize fine threads are stronger than coarse , but am confused as to why it would be necessary to go to fine for the carb attachment - we'll sure as heck be betting that it's not critical.
I should also apologies for my grumpy comment about a metric car with a metric carb and a manifold using old Imperial threads - when the manifold were designed, North America was a long way from being metric, and all the tooling would be for Imperial/SAE. Thanks again, Doug
Roger
Bronze
Fine threads are not only stronger, they can be torqued much more precisely, and don't shake apart as readily. You'd always prefer them on threads used for final assembly.
Bayless
The reason for combination coarse/fine threads on studs is simple. The coarse thread end goes into the permanent part then it is usually easy to tighten and remove the fine threaded end without disturbing the coarse threads. It's pretty common on most double-ended studs.
T
twas_brillig
Chatted with my brother (retired auto mechanic, mostly Fords) last night and he mentioned that Ford used the coarse/fine thread stud combination for attaching carbs to iron manifolds; GM used bolts rather than studs. Just an FYI. Doug
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
steveg TR6 Fixing the intake manifold Triumph 8
Michael Oritt Intake manifold question Austin Healey 11
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
steve00136 MGB Intake manifold alignment MG 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
H BJ8 blew out intake manifold plug Austin Healey 10
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
bugedd Intake Manifold Spridgets 12
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
bugedd Weber intake manifold Spridgets 4
G TR4/4A Intake Manifold Question Triumph 6
S TR4/4A What attaches to the intake manifold Triumph 4
B New Intake Manifold Austin Healey 12
T TR4/4A Intake manifold - what attaches? Triumph 2
J New tube exhaust and intake manifold Austin Healey 15
J TR2/3/3A leak proofing intake/exhaust manifold Triumph 20
mgedit TR2/3/3A Vacuum Leak at Intake Manifold Triumph 6
G TR6 TR6 Intake Manifold interchangability Triumph 10
R Intake Manifold Oddity Austin Healey 20
Patrick67BJ8 BJ8 - Intake Manifold, carb, gaskets sequence - Info needed Austin Healey 2
K TR4/4A Putting H6 SU's on a TR4A intake manifold. Triumph 1
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
philman Wedge TR8 intake manifold coolant nipple Triumph 2
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
E 1981 F150 4.9L intake manifold federal Other Cars 6
Jim_Newman Intake manifold for BN7 Austin Healey 3
Gerard A14 intake manifold needed Spridgets 11
sparkydave 1500 intake manifold snags Spridgets 8
K TR4/4A TR4A long intake manifold on a TR3A? Triumph 17
K TR4/4A Longer TR4A intake manifold on a 3...... Triumph 5
