General Tech Boeing using Lucas parts?
CJD
I was doing a walk around on a 767 and noticed this. It sure looks like Boeing is using Lucas headlights!?!
Jim_Stevens
When only the best will do use Lucas.
David
Actually, you’re not as far off as you think... I work for Northrop Grumman (we make the B-2), which years ago acquired TRW which had previously acquired (you guessed it) Lucas.
Unfortunately (well, fortunately for NGC) our current CEO, being the former president of the TRW group, spun off Lucas as soon as he could....
So our stock price is high, but no employee discount for me!
martx-5
In the first picture, what is that on the tarmac, an oil leak??
Dr_Mike
I believe they used Lucas motors for the wing flaps. ( I had to wait a day for a replacement!) all that stuff about smoke in the wires was just a smokescreen
Michael
Sarastro
Maybe an old time pilot who still believes in relieving himself on the tire for good luck.
David
Or, maybe someone else. I wouldn't be surprised; there are several airlines I'd like to do that to.
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
T Anyone using an LED light like this Triumph 39
