MGB Speedometer and tachometer on '66 MGB are not working
1966MGB
The speedometer in my 1966 MGB was sent to England for refurbishing around 2001. (I trusted restoration of my car to people I oughtn't have.) It never has worked right. The needle swings wildly -- like from zero to 100 -- no matter what speed I drive.
The tachometer was working three years ago. Unfortunately there were circumstances (flat tires ever time I drove it, poor weather, got married, other Life Tasks, etc.) that prevented me from driving my car. Now the tach seems to be 'dead'. No needle movement.
Any ideas as to what might be wrong, and how to fix them?
PAUL161
Check the cables, unusually the problem. Pull them off, pull the cables out of the housing and check for cleanliness and lubrication on the spedo cable. Sounds like the tach cable is broken. PJ
1966MGB
Would this be the appropriate speedometer cable (my car has overdrive), and would this be the correct tachometer cable?
PAUL161
What tach do you have in your car, Mechanical or electronic? Supposedly there was a change between 1962 and 1967. PJ
Platinum
Tach should be electronic from '64 onward, AFAIR. With the engine running, rev to a bit higher than idle and *gently* tap the case from under the dash with a screwdriver handle...
Bouncing speedo is usually cable not lubed well or that angle drive not being snugly fitted to the gearbox. Have a look at the angle drive installation note on the Moss Motors website.
1966MGB
No idea.
Thanks. Now I have an idea. ;)
I'll have the mechanic check it out.
I just got back from a 50-mile round-trip. The tach creeped up, but only up -- not down. It was stuck at about 2,300 when I parked it.
The car ran fine, but I noticed a clattering coming from the engine when I got off of the freeway on the way back. I'll take it to the shop on Monday to see what that's about.
Platinum
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
M TR6 Speedometer Triumph 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
S Speedometer Angle Drive Austin Healey 2
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
M TR4/4A Speedometer Cable Routing Triumph 7
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
B Speedometer Cable Routing Austin Healey 9
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
Michael Oritt Speedometer drive issue Austin Healey 4
R TR4/4A Speedometer off 10mph Triumph 6
R BN7 Speedometer issues Austin Healey 1
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
N Wanted Speedometer or dial Km/h for BT7 Mk II - buy or trade for MPH Austin Healey Classifieds 0
K Speedometer Drive Gear Issue w/ Smitty/Delaney Tx Conversion Austin Healey 16
S Speedometer - BJ8 Austin Healey 4
