Anchoring the Rear Seat Pans
twas_brillig
Each of our squab seats has 4 cross-headed chromed screws, a bit less than 3/4" long, along with a trim washer sticking through them. The seats are not fixed in place as the screws do not seem long enough to penetrate the steel body. I've felt around the underside of the body plus used a mirror to try to have a look (not particularly successfully) and can't find any holes for the screws with this somewhat cursory inspection. I assume I should remove the screws, place the seats, predrill some small diameter holes, and then screw them down. Am I missing something here? Thanks, Doug
NeilJ
I recently helped a guy restore my BJ8 which won gold concours so was done very authentically. I remember him having to sit on the seats so that the bolts penetrated enough for me to apply washers and nuts from underneath. The holes were already in the body so no drilling was involved. Are you talking about your 3000 or your bugeye?
Keoke
I recently helped a guy restore my BJ8 which won gold concourse so was done very authentically. I remember him having to sit on the seats so that the bolts penetrated enough for me to apply washers and nuts from underneath. The holes were already in the body so no drilling was involved. Are you talking about your 3000 or your bugeye?
BJ8 Car seat attachment is different, so they are not ugly.:smile-new:
Rob Glasgow
On my BT7, I have used an ice pick to locate the holes in the body through the rug and sound dreading. You do need screws lolonger than 3/4" to attached the panels.
I never liked the look of the exposed screw heads on the rear seats so on my last restoration, I welded bolts to the bottom of the pans and installed them like the BJ8s.
gonzo
As a matter of preference, if not originality and necessity, the four stainless (#10?) screws were JB welded to the seat pan, then the seats were reupholstered. No exposed screw heads is a cleaner look. Reupholstering the pans was interesting: there are holes in the middle of the seat to catch seat bottom material with needle and thread. Good luck.
BJ8Healeys
I did just the opposite. My BJ8 already had several of the rear seat studs broken off when I bought the car. I didn't like the idea of having to remove the rear wheels to access the nuts to remove the rear seat pans, so I installed anchor nuts on the seat structure to accept screws from above. That makes it much more convenient to remove the right rear seat for access to the fuel pumps (I have two), the fuel filter, and the differential for adding oil without having to put remove the wheel or put the car up on jack stands. With a yellow and black paint job, obviously I'm not particularly Concourse (or Concours) - oriented. The chromed screws and cupped washers look reasonably original to anyone who doesn't know.
T
twas_brillig
Thanks guys - I picked up some longer stainless screws and we were able to probe and find the various holes and the seat squabs are now securely mounted. Question though: my intention was to transfer the 'cups' from the original screws onto the longer replacements, but couldn't remove them. I was thinking that I'd try to removing the 'new-longer' screws and replacing them with the orignals now that they are screwed down (in case the shorter lengths will now work); if this doesn't work, are there any suggestions regards transferring the 'cups'? Thanks, Doug
T
twas_brillig
FYI: we used 8x1 oval head Phillips stainless sheet metal screws; they look the same but take a slightly different screwdriver. Doug
Deamaker 5
The bottom of them I never liked the look of the exposed screw heads on the rear seats so on my last restoration, I welded bolts to the bottom of the pans and installed them like the BJ8s.
What if your seats are already covered with leather - would u still weld on the bottom of them ?
Rob Glasgow
I think if you peeled he leather back from the hole locations you could carefully tack some screws to the pan. Another suggestion is to peel the leather back and use some JB Weld to fasten the bolts in place. Use oval head bolts and insert from the top side. Then glue the leather back in place.
Deamaker 5
Thanks for the tip
John Turney
One can buy the trim washers separately at a quality local hardware store. I like having the seat pan easily removable to get to the fuel filter on my BN4 (which should have the exposed screw heads anyway).
Deamaker 5
That’s a good point , u never know when that fuel pump will give out
bob hughes
I have used some hefty self tappers at the moment and only 2 per seat, as I am always removing them to get at things. When I get around to buying in the proper seat covers for front and back I might consider welding in studs on the tractor seats.
:cheers:
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
drooartz Bugeye jack points to remove rear axle Spridgets 18
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
