Steering warning
steveg
I fouled up my steering to the tune of several hundred $$$ by releasing the front plate too far in order to drain the old penrite. In future will only allow it to open 1/8" or less.
As a result the rear bearing slipped down around the shaft and when I tightened the front plate, the rear bearing did not seat in the race and destroyed both the fixed race on the worm, the rear bearing itself and the replaceable cup race adjacent in the housing.
As a result, am buying a new worm and peg from DWR. Fortunately am able to score used bearings and races from friends with used boxes.
Michael Oritt
Steve--
Sorry to read of your distress--I have been guilty of unintentional self-inflicted wounds and they sting terribly. Just the other day I misread the wiring diagram for a WOLO Hi-Low air horn and hooked up the relay improperly. $57.00 and a new compressor later I got it right....
Though I am not having any steering issues I have read DW's great claims for their unit and I hope you will favor us with a report when you get the replacement installed.
elrey
Thanx for posting the warning, I prefer to learn from other's mistakes. I make enough on my own. Regularly. :wall: .......:cheers:
gonzo
Gulp! We learn more from mistakes self inflicted or otherwise.
DWR steering racks are tasty bits of engineering. Perhaps you subconsciously wanted one? You'll be happy with the swap. The dynamator installed on my car packed up over the weekend - it's not charging anymore. Maybe all the fan belt pulley monkey business was the cause of its premature demise ($$). Had to re-install the generator. Gives me an excuse to take apart the dynamator to see what's what. Gonzo
Michael Oritt
Gonzo--
You said "steering rack" but my understanding is that the DW unit is still worm (sector) and gear for which they claim great improvement over the stock unit.
I don't know of anyone who has installed the DW unit on their Healey and am simply interested in learning how it works out. Steve must obviously put in a replacement unit and is upgrading to the DW over the usual--I hope the extra cost is worth it.
steveg
steveg
Gonzo--
If you have to buy the column with worm, with matching peg, Moss is $950 + shipping; DWR is $556 including shipping.
DWR--and, probably most of the Brit sellers--are often the best deal if you can wait a week or two (longer if Customs gets baffled by Healey parts*). T'was even better a year or so ago, when the £ was weaker.
* I bought some gearbox and OD parts from DWR last year. Customs wanted to know not only what they were--granted, a 1st/2nd sliding shift hub might look sinister in the wrong context--but what they were made of (steel, brass, rubber, etc.). I am so not kidding. To be fair to Customs--well, not really--DWR messed-up the manifest, which started the confusion.
Michael Oritt
Steve--
That's a big difference. Do you have any knowledge as to DW's claim that their part is superior?
steveg
steveg
Steve--
DW is claiming their part to be superior to the originals. Will it result in a superior driving experience? Will report back after mine's installed.
Two friends have installed the complete DWR steering boxes and swear by them. Mechanic Russ Thompson swears by them.
I'm guessing the Moss parts would be made by the same process and therefore equivalent.
Michael Oritt
Steve--
Did you get the high or standard ratio column? Though high-ratio steering usually makes for more effort I would think that the lighter weight of a 100, relative to a 6 cylinder car, should make this acceptable.
steveg
steveg
Steve--
I bought the regular-ratio LHD adjustable.
steveg
steveg
Am installing my DWR steering worm and peg. To prevent further problems, installed a clamp-on sleeve made from a piece of 1" EMT. This becomes a "step" to make sure the bearing doesn't get hung up again if I loosen the front plate.
Couple of observations from my situation:
--Corn head grease will not drain - if I need it out, will have to remove the box and scoop it out. On the other hand, it's inexpensive and easy to install on the bench and probably less likely to leak.
--Corn head grease mixes easily with oil for recycling.
--Inserting the three mounting bolts from the fender side ensures ability to remove box/column without removing radiator.
Michael Oritt
Good luck and please let us know how it turns out.
dougie
Steve--
I replaced the worn stock unit in my '57 vintage racer with a DWR high ratio unit last year. In short, I love it. The stock unit I replaced was well past worn and probably should have been replace much earlier.
Lin
Dougie,
‘would you put the high ratio in your BJ8 or stick with the standard?
Lin
Michael Oritt
Dougie--
How many turns are there lock to lock in the High Ratio and is more steering effort needed?
dougie
Dougie,
Lin
If my BJ8 needed new steering, I would go with the high ratio, easier to handle in tight places. On the track, it takes much less imput to get around the track.
bluemiata90 TR4/4A TR4A steering coupling warning Triumph 2
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
W Steering Arm Colors Spridgets 1
