Results 1 to 10 of 10
Thread: Vintage Radio
  1. #1
    Join Date
    Dec 2014
    Location
    Warner Robins, GA, USA
    Posts
    5
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Vintage Radio
    My 1964 BJ8 came with a vintage radio in a box along with some other parts. There is no identification on the radio except the dial face says "All Transistor". It is an AM pushbutton, with a switch on the back for neg or pos ground. There is no speaker with it. Do the radios of this vintage require 4 ohm or 8ohm speaker, or does it make any difference?
  2. #2
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,535
    Thanks Thanks Given
    12
    Thanked in
    Re: Vintage Radio
    Hubert, I don't have any expert knowledge about radios but I have a vintage radio for an old Corvette that I have been planning to get done. In that here is a fellow that with his wife restores and upgrades vintage radios of all makes. I have run into him a number of times at his booth at the Carlisle Car Shows through out the year. At Carlisle, Pa. He is an older gentleman whom I believe is retired from another career but he has been at these Car Shows for many years. He has always been enjoyable to talk to and volunteers any information easily about radios and electronics. I believe he will help you with all your vintage radio needs.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  3. #3
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,202
    Thanks Thanks Given
    6
    3
    Thanked in
    Re: Vintage Radio
    You should be able to run either, all other things being equal you will get more volume out of 4 ohm speakers. On old cars/radios with limited amps they did 4 ohms for that reason, then 8 ohms kind of became the default, and now with modern high power amps they have gone back to 4 ohms for high power stuff.
  4. #4
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,435
    Thanks Thanks Given
    6
    Thanked in
    Re: Vintage Radio
    Audio Power transfer between a radio or an audio amplifier are maximum if and only if the output impedance's of the device and its speaker are are matched.
    I am sure a little research on google can solve this Radio,s output impedance.
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  5. #5
    Join Date
    Aug 2017
    Location
    Oceanside, NY
    Posts
    21
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Re: Vintage Radio
    Quote Originally Posted by Keoke View Post
    Even in the case where a radio is designed to work with an 8 Ohm speaker impedance, the amplifier section will try and deliver twice the power at 4 Ohms. However, distortion may well be be higher as the amplifier is potentially being overloaded.
    See here:
    https://geoffthegreygeek.com/speaker-impedance-changes-amplifier-power/
    https://www.gcaudio.com/tips-tricks/...nd-amplifiers/
  6. #6
    Jedi Knight smaceng's Avatar
    Join Date
    Nov 2008
    Location
    Martinez, CA
    Posts
    1,146
    Thanks Thanks Given
    Thanked in
    Re: Vintage Radio
    Make sure the polarity of the radio is the same as the Healey.
    If you hook it up wrong, most likely the radio will be toast.
    Cheers,
    Scott in CA
    1973 TR6
  7. #7
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,710
    Thanks Thanks Given
    6
    Thanked in
    Re: Vintage Radio
    Can you get AM broadcasts these days? I suppose that there must be something in the Ether
  8. #8
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,570
    Thanks Thanks Given
    1
    32
    Thanked in
    Re: Vintage Radio
    Quote Originally Posted by Bob Hughes View Post
    Over here, it's sports, right-wing talk and Spanish language stations.
  9. #9
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,710
    Thanks Thanks Given
    6
    Thanked in
    Re: Vintage Radio
    Right
    It's so old
    I don't suppose that they have the results on the Battle of Waterloo!
  10. #10
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,435
    Thanks Thanks Given
    6
    Thanked in
    Re: Vintage Radio
    Right
    It's so old
    Well:
    Maybe if you happen to dial in on" What happened on June 18 "---.
    1985 XJ6 Saloon
    1973 Volvo P1800ES
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
