overspray removal on vinyl
Hangtown Healey
Boy, I hate painters. Every problem is the customers fault and the customer must spend 2 hours clean up to every billed hour by the painter.
So how do I get rid of overspray on my BJ8's vinyl? The upholstery guy says wax and grease remover(prepsol). So far not effective. I am about ready for lacquer thinner.
Ken Freese
RA_Healey
I have used enamel reducer sparingly applying it with the finest steel wool, ooo? Be careful only work it for short periods. I cleaned off with 409 and then waited to apply again. Working too long will start to melt the vinyl. Good luck.
Patrick67BJ8
I would post that question on one of the Auto Detailing Facebook pages. Great resource for spills, stains, paint correction, etc, etc.
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
eschneider paint overspray on leather Restoration & Tools 7
J SafelyRemoving Paint Overspray from radiator fins? Austin Healey 8
T Clearcoat overspray in engine compartment Triumph 1
KLUTZ Overspray on inside panels Restoration & Tools 1
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
C MGB Rubber Bumper cover removal MG 5
kodpkd Antenna Removal Austin Healey 9
B General MG Crankshaft Nut Removal MG 4
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
W BN1 Steering Box Removal Austin Healey 11
S TR2/3/3A engine removal Triumph 12
S TR2/3/3A Steering wheel removal. Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
C MGA Dash removal MG 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
R TR2/3/3A Steering wheel hub removal Triumph 11
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
D Heater knob removal Spridgets 6
S 1275 oil pan removal Spridgets 30
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
E austin van heater removal Other British Cars 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
nevets Water Pump Removal Austin Healey 6
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
F Interior Door Handle Removal Austin Healey 2
Z Front Springs Removal Austin Healey 3
R Oil Filter Removal Austin Healey 1
C MGA R/H tail lamp removal on a 1962 MG 5
K TR2/3/3A Removal of tie rod end? Triumph 7
J Ignition Key Cylinder Removal Austin Healey 3
J Planetary Gear Removal Austin Healey 3
Walter74 Adjustable steering wheel removal Austin Healey 4
E MGB 1965 mgb fuel pump removal MG 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
T BJ8 Drain Channel Removal Austin Healey 2
D TR2/3/3A Facia removal steps Triumph 3
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Spitfire Triumph spit flange/hub removal Triumph 13
