TR4/4A steering shaft/nut thread size
Rut
Good morning all! I'm ordering a tap and die for the steering shaft/nut for a 4a and I've narrowed it down to a 9/16-24 or 28, but I'm not convinced it's either. Does anyone have a definitive answer on the correct size?
Thanks, Rut
titanic
Rut-If the TR6 is the same as TR4A (and I think it is), I measured the steering shaft at .553" and 27 tpi. If you are trying to clean up the starting thread, you might consider one of the thread restoring tools that follows the existing threads.
Berry
Rut
Rut
Thanks, one shop measured it at 9/16-24, so I'm trying to get an exact number before I order.
Rut
Rut
Rut
From what I've been able to find out from several different sources on the internet is that the most popular guess/suggestion/measurement is 9/16-27. I was lucky enough to find both the tap and die for about $10 + $4.98 shipping...for $15 I'll take the chance since I have 4 shafts and nuts to clean up! I hope this size is eventually confirmed by the forum or by me in a couple of weeks, and I'll post back with my success or failure. Berry, thanks for your measurements and I'll check my TR6 as well. My Bugeye came with a TR6 steering wheel and a TR4 steering wheel fits as well, so I don't have to pull that rusty nut off the TR6 after all!
Thanks, Rut
Rut
Rut
Berry,
Thanks for your info on this and it looks like mine will be 9/16-27!��
Rut
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
Rut MGB 62-67 upper MGB steering shaft MG 3
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
Popeye TR4/4A Steering shaft rebuild Triumph 3
steveg Steering shaft repair Austin Healey 1
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
JFS Wedge Steering shaft / fire wall grommet Triumph 2
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
R BJ7 Steering Gear and Idler Rock shaft Austin Healey 4
Zitch Steering shaft Thread Triumph 22
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
T TR4/4A TR4a steering shaft play Triumph 21
B About the steering shaft brackets Triumph 2
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
J Shorten the steering shaft ? Austin Healey 4
dklawson Spitfire Spitfire Steering Shaft Coupling Construction Triumph 9
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
M TR6 play in upper part of steering shaft tr6? Triumph 2
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
