I need to adjust the float lever on the sending unit as mine reads 1/4; when the tank is empty. I have attached a wire to the arm and do get a Full reading when I raise it to the top. Pushing it to the bottom gives me a 1/4 reading. I have managed to remove the 6 screws holding the unit in, but can't get it out as the unit is bigger then the distance above the tank.
