bthompson
My magic 8-ball still thinks you're running rich because of the carb, and flooding the engine when its warm. Definitely pull the plugs and check. When you rebuilt the carb, did you replace the jet as well as the needle? Zenith needles are spring-loaded and run against the side of the jet, which can run the jet oval over the years.
Is your float valve leaky, or the float porous, or set incorrectly? The fuel level will then be too high in the bowl, and the jet will always push too much fuel through.
Is the butterfly rod loose in the bushings? If so, it may be the source of a vacuum leak that drives the Zenith richer.
And the big question: are you running the original air cleaner? Zeniths are calibrated to take the restriction of the air cleaner into account. If you use low-restriction, high-flow air filters, it'll "fool" the carb into running too rich.
It's true that most problems that look like fuel are really electrical, but if your electrics are in good nick, there're a lot of Z/S issues that can be caused by vacuum leaks. All the small leaks are additive, and they all have the same result: drive the system richer.
