Zip-Out Rear Window on a BN-7 Top?
mrunci
Many years ago I found one of the many joys of owning a BJ-8 was the possibility of driving with the hood (top) up while leaving the rear window open. Great air flow on hot summer days!
I now own a BN-7 which as we all know does not afford that possibility in stock form.
Has anyone heard of modifications being done to an original-type roadster hood that would offer that same feature? If not is custom manufacture of a hood modified in this way even possible and if so does anyone know of a source?
bob hughes
No, but I can not think of a reason why it can not be done - at a price of course, I know of a BJ8 that has had the soft top and rear shroud modified to allow the fabric to cover the frame like a BT7, because the owner some times uses a hard top and then changes to a soft top at the drop of a hat. I suspect but do not know for sure that the hard top may be for a BT7 and hence the soft top had to be removed in total to get it to fit.
:cheers:
Bob McElwee
I had a zipper installed in my BT7 by a shop that did car upholstery and top installation. It was a long time ago and i don't remember the cost. Be sure to make sure they will put the zipper 'slider' on both side to meet in the middle like on the BJ8. One is workable but a hassle sometimes.
You are correct, it is great for highway driving on hot summer days.
steveg
Ken Rocke has built at least a couple of 2-seater tops (maybe 3 - 4) with zip-out rear windows - from scratch. He told me a stock top can't be modified this way. He may have told me why (long forgotten), but I took him at his word. No contact info.
stretchit2
A Souther California club member has one. It may be that this is one of the tops made by Ken Rocke
BLU_HLY
I have tops for the BN1 and BN2 with zip- out rear windows. The source was AH Spares and this request was not an additional charge. Just specify the modification required.No other sources for tops would accept this modification !!!
M
mrunci
Guys, I appreciate your responses. The photos are particularly helpful for me because they bring into focus perhaps the one continuing problem with this arrangement, i.e., if the wind remains attached along the bottom seam, it must remain rolled or somehow folded on the rear shroud deck. It cannot be folded downward into the cockpit as is the case on a BJ-7 or BJ-8. As a practical matter this would mean poor aerodynamics as the window portion would flop around in the wind at speed. This would obviously risk compromising the paint surface on the deck, not to mention the structural integrity of the window itself. Somehow I hadn't been able to anticipate this as I stared at my top. The photos were really of great help.
I will consult with an upholstery and top specialist to be sure but I'm a little more skeptical about modifying an existing top than I was when I first posted this note.
Building a new one from scratch may be the better solution.
Thanks again very much.
RAC68
Hi Mat,
I have spend many hours repair-sewing the zip-out rear window on my BJ8 and have learned a number of things relating to its construction and support. Your BN7 top substantially depends upon its in-place rear window to maintain all-round rear support as air passes over the top and then blows in a forward direction at the window. With door windows not in place (open), air coming through also acts to push on the window to add a counter force to the forward pressure provided by the outside air flow.
If I were doing the window modification you are looking to do, I would consider having the rear window unzipped and completely removable to be stowed separately. Additionally, consider having the rear top frame support completely wrapped to provide additional support and secured and detachable with a lengthwise zipper, similar to the BJ8. Also, with the window removed, I would make sure there is ridged support and attachment across the bottom of the window opening and added body contact support at each end of the rear window opening.
I very much appreciate your objective and do appreciate the effort and chance of experiencing unexpected conditions that would need to be addressed. However, I often drive during a hot summer day with the top up and rear window folded down and appreciate the benefit you are looking to achieve.
All the best,
Ray(64BJ8P1)
Bob McElwee
Matt, we put many, many miles on two lanes and interstates with the window zipped down. We just laid it on top of the 'luggage' that was in the back seat. When there was no luggage, it just laid over the back seat. Never had any problems with the top driving that way. If the side curtains were mounted on the car, the back window was zipped up. We rarely ever used the side curtains unless it was really cold or we knew we were going to hit heavy rain for an extended period of time. We had the side mounted air deflectors that normally made driving bearable if not enjoyable.
M TR4/4A tr4 zip out rear window Triumph 6
RickB Another soft top question - zip out rear window? Spridgets 43
S Had it's own zip code...... Spotted 1
Geo Hahn HF SS Zip Ties Triumph 14
T old guy string vs. zip ties Spridgets 8
RickB Zip down window - rolled & fastened Spridgets 13
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
