garrygriffin
I need some assistance with a carb problem. I have just finished restoring a 1973 Triumph TR6 with Zenith Stromberg carbs. As the car was in pieces when I started, I'm having some difficulty getting things plumbed correctly. The rear carb has what appears to be two vacum fittings on it. One on top near where it bolts to the manifold and one on the bottom. I believe the bottom fitting goes to the distributor (originally via the vacum-temp switch located on the top rad hose and now missing on my car). I have no idea where the top fitting connects to? I seem to be able to find diagrams for later years and earlier years, both of which are different as the 1973 is pre-air pump and the 72 seems different again. Thank you for any assistance.
Garry
Garry
