swift6
Randall and I could probably go back and forth arguing different points of physics theories, applications and more regarding the internal workings of the internal combustion engine. There is a whole lot more going on than either of us have even begun to speak about.
But I'm not going to. Frankly its unnecessary distraction from the original question which was to offer a guess as to whether any damage had been done in the first 4,000 miles without ZDDP.
The most direct answer to this question is, we really have no idea and a guess is just a guess and worth as much as you pay for it. If the cam/lifters were properly broken in, and they are not poor quality pieces, then you might be okay with the reduced ZDDP levels of modern oil. Or, the damage could already be done and component life may have been shortened. Whether that means you might see failure tomorrow, in 5,000 miles, 20,000 miles or 80,000 miles is not really answerable at this time. The only way to know for sure if there has been any damage is to remove the cam and lifters and examine them. As an alternative, sending samples of oil off for analysis may also yield good information for you.
In the meantime, using an additive to return your choice of oil to the older ZDDP levels, or using an oil with those higher ZDDP levels could be considered cheap insurance.
